20 Most Recent
Taylor Body Fat Analyzer & Scale, Model 5571 Questions & Answers
Can't find my manual to figure out what where I am
Taylor customer service should be able to answer you questions over the phone as well as send you a new manual. Here is their phone number 1-866-843-3905. Their website is http://www.taylorusa.com/taylor-support. I hope this helps. :)
Tells different wieght each time
Does it tell you a different weight each time you weigh yourself in the same few times? Or day by day?
If its consecutive uses that give you different weights, if you're within 0.2kg, I wouldn't be surprised if the scale can't do better.
Otherwise, weigh yourself each day at the same time, and take an average of 3 weighings for the 'best' weighing.
Say it in English,not British
1. Turn the unit on.
2. At the same time, press and hold the "G" button and the power button.
3. While continuing to hold down the "G" button, release the power button.
4. Release the "G" button.
5. If you have done this correctly, the unit will power on. This procedure will switch back and forth between lbs. and kg.
