20 Most Recent Salter Aquatronic Glass Platform Electronic Kitchen Scale Questions & Answers
0answers
Salter 3003 error
Be the first to answer 1/20/2013 6:45:44 AM • Salter... • Posted on Jan 20, 2013Be the first to answer
2answers
My Salter Electronic scales will not pass EeeE even after replacing with new battery. What do I do next please?
Probably the sensor is damaged and time to replace the scales unless it is still under the manufacturers warranty, in which case, return it for service.
4/15/2024 9:44:27 PM • Salter Health &... • Answered on Apr 15, 2024
2answers
My Salter digital bathroom scale is stuck on kilograms. I`ve changed the battery and used cleaner on the sliding selector but it will only show stones or Kg.
See if you can find the manual for your model. It sounds like you have a British model and not one that has US units. http://www.manualsdir.com/brands/salter/41.html
10/3/2023 11:07:47 AM • Salter Health &... • Answered on Oct 03, 2023
No ere didn't come off Salter 1250 scale.
4/24/2023 4:22:18 AM • Salter Health &... • Answered on Apr 24, 2023
Salter electronic bathroom scales suddenly stopped working and showing code EL. New battery inserted but still showing code in both kg and lb. Any suggestions?
Hold the two arrow and set buttons together for a few seconds and it may clear.
2/26/2022 6:43:00 PM • Salter Health &... • Answered on Feb 26, 2022
Why did the new 9 volt battery in put into a Salter food scale get hot within minutes? there was a chemical smell as well. something wrong with the battery or the scale? could it cause a fire?
I have never known a food scale take a 9 volt battery. Mine takes x CR2032 3 volt button battery. Google make model manual
12/12/2021 6:52:17 PM • Salter Health &... • Answered on Dec 12, 2021
2answers
Does Salter Ultimate bathroom scales have one or two batteries
2 batteries
12/4/2021 5:23:28 PM • Salter Health &... • Answered on Dec 04, 2021
Error code bathroom scales
O-ld is 'overload'. There are some fixes here. The first thing I would do is remove the battery and leave it overnight. Replace the batteries with new ones. If you think it may be possible that you are overloading the scale, put a bag of sugar or flour on them to test.https://www.google.com/search?q=Salter+bathroom+scales+0-ld+code..
11/14/2021 11:59:10 PM • Salter Health &... • Answered on Nov 14, 2021
Model 9069 bathroom scales. Why doesn't it settle on a weight?
The replacement battery could be defective or incorrectly installed. Aside from that, the the scales may have simply failed.
1/11/2021 2:10:36 PM • Salter Health &... • Answered on Jan 11, 2021
What does the error code EE mean on the Salter 1066 kitchen scales
Either you are trying to weigh something that is too heavy or the damage has already been done and the sensor has been damaged with excess weight. I bought a set just recently from ASDA (Wallmart) and they cost less than £10.
1/11/2021 10:56:51 AM • Salter Health &... • Answered on Jan 11, 2021
I just changed the batteries in my Salter scale 2010 and I get: EE. Do you know what that means and how I can get the scale to work? Thanks
The EE code means there is an error, possibly because the replacement batteries are defective or installed incorrectly.
1/3/2021 8:03:04 PM • Salter Health &... • Answered on Jan 03, 2021
What does message J.J mean on my Salter kitchen scale model 1015 when I try to weight food on it?
I think it will help https://slavinasmile.ru/
10/31/2020 9:20:29 PM • Salter Health &... • Answered on Oct 31, 2020
2answers
Digital scale. It reads "unst". How do I fix it?
"unk"
9/30/2020 7:07:45 AM • Salter Health &... • Answered on Sep 30, 2020
2answers
How do i get battery compartment open on Salter kitchen scale model 2006
I went to the Salter website and I could not find that model number. Salter Disc Electronic Digital Kitchen Scales White However, looking at the other models they had there should be a door on the bottom of the scale. It looks like a release tab that you push in then lift up on. Give that a try.
2/26/2020 2:05:09 AM • Salter Health &... • Answered on Feb 26, 2020
How do I Reset Salter Electronic Scales 9106
Salter 9106 Manuals https://www.manualslib.com/products/Salter-9106-5886655.html Salter 9106 Pdf User Manuals. View online or download Salter 9106 Instruction Manual. ... 2. How Does the Salter Scale Work. 3. Faq. 3. Display Guide/Function ...
1/31/2020 12:35:00 PM • Salter Health &... • Answered on Jan 31, 2020
My digital kitchen scales have started showing 12.00 on the screen. I've tried removing the battery for r10 mins and replacing but problem is not solved. Help!
Remove all batteries from the back of your scale.
Leave the scale without its batteries for at least 10 minutes.
Reinsert the batteries. Check that the batteries have the correct polarity and are firmly in place.
Place your scale on a flat, even surface without carpet.
Press the center of the scale with one hand to wake it up. The scale will calibrate and display a series of dashes.
"0.0" will appear on the screen. Press on the center of the scale.
11/8/2019 9:47:01 PM • Salter Health &... • Answered on Nov 08, 2019
Salter Aquatronic Glass Platform Electronic Kitchen Scale Logo
4 questions posted
Top Salter Health & Beauty Experts
vince
jws1013
Ngoro
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Salter Health & Beauty
Most Popular Question
did new 9 volt battery in put into
  • Health & Beauty
