20 Most Recent
Soehnle 63700 Calando Quattrotronic Scale Questions & Answers
I purchased bathroom scales in
It is an electronic scale so it does need the battery to function proper..though it may give some readings without ..probably the battery place is for another memory functions like ..history ...or ...showing difference ..or so ..
first of all if it seam that it has major difference from one day to another be sure you have set the right measurement unit ..cause if it is in odd one the difference may be considerable and if you are used in Kg or so its understandable.. so ..what you actually need is a user guide for it to be sure you use it right ..and to be placed in a perfect horizontal position ..I will look for a manual ..but I need the manufacturer name and model .... the serial is not relevant cause it may be almost anything ..
Need a manual to find out how to set the scales
I'm afraid I can't tell you how to re-set your scales, but these days the UK is part of Europe, and like it or not, we all need to get used to thinking in kilos (and, for that matter, in metres instead of yards).
1 kilo = 2.2 lbs. So all you need to do is to take the kilo figure and multiply it by 2.2 to get your weight in lbs. So if, for example, your scales show 60 kilos, multiply that by 2.2 and you get 132 lbs.
I recently purchased a Soehnle
Look around and see if it has a reset button ...and reset it to factory settings ..Probably happened with it ..or cause it repeated you are doing something wrong when you set it .....probably you lock it in the last read ..cause it indicates the same measurement ..So ..all devices like that have to have a reset button ...locate it ..(it may be in the menu as a feature..and called different probably ..factory defaults or factory settings ..or reset all ..) and after you engage the reset it will work again ..but ..read the manual carefully and see what are you doing wrong ...
How many protein bars should I eat per day?
Go with whole food proteins or quality whey shake. Make sure you know what you are eating, Cliff is probably one of the highest rated ones, so two bars would be fine along with normal meals. Whey protein is a naturally complete protein, meaning that it contains all of the essential amino acids required in the daily diet.
Whey protein is a rich source of branched chain amino acids (BCAAs), containing the highest known levels of any natural food source. BCAAs are important for athletes since unlike the other essential amino acids, they are metabolized directly into muscle tissue and are the first ones used during periods of exercise and resistance training.
Whey protein provides the body with BCAAs to replenish depleted levels and start repairing and rebuilding lean muscle tissue.
How often should I visit my dentist?
Most adult and children visit the dentist for regular
checkups and cleanings every six months. People at greater risk should have
checkups more often.
