20 Most Recent Clark Forklift Horn Button Switch , Cat Etc Questions & Answers
HOW TO CLEAR CODE CANBUS ERROR 2 ON CLARK FORKLIFT?
Hi, I have clark forklift not starting error: canbus error 1
2/9/2021 6:49:20 AM • Clark Forklift... • Answered on Feb 09, 2021
2answers
Clark Forklift GPX25 will not shift into reverse.
I got the same problem and same model, what's going on with Clark forklift, I look for the new transmission all over internet but can't find any. if any body know what wrong please tell us what to do. thanks a lot. TMV
2/21/2018 3:06:51 PM • Clark Forklift... • Answered on Feb 21, 2018
Clark forklift with error code
The description for code 15 is battery voltage to low. The code will flash when the battery volts are less than 1.95 volts per cell when the key is turned ON. Check the battery voltage with volt meter at battery were positive and negative connect. If the battery is 36 volt it should be no less than 35.1 volts, if the battery is 48 volt it should be no less than 46.8 volts. If battery voltage is low check each cell indavidually to locate a bad cell, each cell should have around 1.95 volts, if a couple are dramatically lower that may be your problem. If the battery checks out check your cables and connections (this seems likely because you say its after you charge battery, when you plug and unplug your battery in you wiggle the cables around witch could cause a poor connection.) Check over your cables carefully as corosion can grow inside of them especially near the battery and connector. Hopefully this helps, looking forward to positive feedback thanks.
1/30/2018 7:30:29 AM • Clark Forklift... • Answered on Jan 30, 2018
Tm 20 clark forklift error code -46 what does it
sounds like the #1 rectifier is shorted or the insulator gasket is shorted through -also the 1A contactor may be welded shut -usually caused by a weak battery or running a discharged battery too long. -Troy from A-Lift Services
4/5/2017 10:40:15 PM • Clark Forklift... • Answered on Apr 05, 2017
3answers
Problem with Clark forklift TMX12-25 TMX250
It means it's time for your periodic maintenance, the reset button should be close to hour meter
4/17/2015 7:40:01 PM • Clark Forklift... • Answered on Apr 17, 2015
0answers
0answers
0answers
2answers
I have a clark fork lift that sometime works fine
check the amount of hydrlic fluid in resivor, sounds like you are low. if it is full your bleed back valve is sticking open
9/25/2013 11:51:56 AM • Clark Forklift... • Answered on Sep 25, 2013
Clark Forklift Horn Button Switch  , Cat Etc Logo
76 questions posted
Top Clark Electrical Supplies Experts
Aron
Don A
Don A
Simon Atkinson
Simon Atkinson
Are you a Clark Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Clark Electrical Supplies
Most Popular Question
  • Electrical Supplies
