20 Most Recent
Black & Decker Cafe Noir DCM1400 Coffee Maker Questions & Answers
Filter basket retains water
it sounds like a restriction in the perk tubes have you cleaned I mean deep clean the unit??? It should be as any auto coffe maker should be clean deeply every three to six Months depending on how much you use it. How you do this is take 1/2 viniger in pot and fill to capacity.. Dump this into the unit and brew it through. Then ite recommended to rinse them by brewing three to 4 times with clkean water. now if this dosent work its probably behound feasability to repair
Coffee does not brew
the heater eleiment is bad or the thermal fuses conncting the elements are blown
I have black & decker pw1400s it is possible to connect the water faucet
It will depend on what kind of faucet it is. You can get adapters for the faucet on your kitchen sink but I find they are not very good for pressure washers. They can leak and spray water all over your sink and kitchen. For a pressure washer it is best to have an outside faucet fitted. This will give you the correct type of faucet to connect to and a good supply of water to the pressure washer.
It is usually not very expensive to get one fitted.
Black & Decker CM1609 keeps shutting off in the middle of making coffee
I had my black& Decker for about 6 months or so and it started shutting off after a minute or two of brewing. I cleaned it by running 5 cups white vinagar through it twice and using a filter in basket. Then running 2 pots of clean water through. I had to keep turning it on but by they end of later last pot of water rinse it stay on all they way through .there was an incredible about of lime built up . try it worked for me.
Model CM1609 received as a gift 2 months ago. From
I would not have waited this long to get a warranty replacement. If you need the proof of purchase, you will have to ask the person who gifted you. Hopefully, the giver will be understanding and help you out.
