20 Most Recent Black & Decker SpaceMaker ODC325 Coffee Maker Questions & Answers
2answers
Digital clock will not keep
The clock will need to be changed by a appliance repair shop. The repair may cost more the the machine is worth.
8/20/2021 11:15:41 PM • Black & Decker... • Answered on Aug 20, 2021
Black and Decker space maker coffeemaker
I posted this for Chiefbvf earlier: The thermal cutoff switch part number is 36TMH0110603L320-32F (cuts off between 320 and 332F), which I can't find for sale. There is a slightly different one available, however, which cuts off between 315 and 350F, but I can't find an outlet that sells singles. If you can find someone who sells individual parts with serial no: 36TMH0110539L315-50F let me know.
1/24/2019 11:10:42 PM • Black & Decker... • Answered on Jan 24, 2019
4answers
Black & Decker SpaceMaker leaks badly.
It has nothing to do with the spring or its tension. I have had 3 of these coffee makers now. Each on has started leaking water from the reservoir after some amount of time. If you carefully look at where the rubber washer/spring thing is, right above the hole where it goes in, you will see a small "crack" in the plastic that develops after repeated use of this coffee maker. That's where the water is coming from. Each one of the reservoirs I have had has developed this crack in the plastic right there. It is a design flaw. I will never buy one of these again.
4/5/2017 1:36:51 PM • Black & Decker... • Answered on Apr 05, 2017
Cant find part for spacemaker!
If you type in the part number in Google, several repair parts dealers should show up. If they can't help you, try contacting the service department at B&D directly to see if the part is available. Sometimes, the manufacturer won't sell certain parts to anyone except authorized service centers.
6/2/2015 7:20:14 PM • Black & Decker... • Answered on Jun 02, 2015
Heating element on B&D Spacemaker ODC325 coffeemaker quits
The part number is 36TMH0110603L320-32F (cuts off between 320 and 332F), which I can't find for sale. There is a slightly different one available, however, which cuts off between 315 and 350F, but I can't find an outlet that sells singles. If you can find someone who sells individual parts with serial no: 36TMH0110539L315-50F let me know.
3/18/2015 5:14:26 PM • Black & Decker... • Answered on Mar 18, 2015
2answers
Doesnt work
The thermal cutoff switch is probably stuck (blown) open and won't reset. It mounts on (against) the heater unit, and the part number is 36TMH0110603L320-32F (cuts off between 320 and 332F). I can't find any for sale, but there is a slightly different one available which cuts off between 315 and 350F. The problem is I can't find an outlet that sells singles of those. If you can find someone who sells individual parts with serial no: 36TMH0110539L315-50F let me know.
3/18/2015 5:12:48 PM • Black & Decker... • Answered on Mar 18, 2015
Black and decker coffee maker - water pools in coffee filter
Be sure the carafe is pushed all the way back. It must push the lever on the back of the machine in order to open the valve on the filter holder
3/17/2015 4:14:14 AM • Black & Decker... • Answered on Mar 17, 2015
I need bracket
There's one on sale on eBay right now. Just search eBay under ODC 325.
5/9/2014 1:22:06 AM • Black & Decker... • Answered on May 09, 2014
I have a spacemaker that leeks at resover
Used/Cannibaliized Replacement parts for ODC 325 B&D Spacemaker Coffee Makers are regularly sold on eBay, including the entire water reservoir or even the water valve in bottom of the reservoir (the leaky old one can be pushed out from the inside of the reservoir, and a non-leaking used replacement valve can be pressed in in its place).I sometimes buy an old broken ODC 325 cheaply on eBay as a source of parts.
5/9/2014 12:53:34 AM • Black & Decker... • Answered on May 09, 2014
Spacemaker coffee
Which components of the Black & Decker SpaceMaker ODC325 Coffee Maker are you referring to? Hanging the entire assembly under a kitchen cabinet, inserting the water reservoir or coffee holder into the unit, or what?
5/8/2014 11:18:27 PM • Black & Decker... • Answered on May 08, 2014
Water resevoir leaking
Replacement ODC 325 water reservoirs no longer for sale.
I keep a second ODC 325 machine for canibalization. The black rubber water valve assambly can be repaired (I did it 2 weeks ago) but it takes some creativity.
5/8/2014 10:43:05 PM • Black & Decker... • Answered on May 08, 2014
Email for b&d
visit http://www.blackanddecker.com/Customer-Service.aspx you'll find email address there for kitchen appliances.
5/8/2014 8:41:40 PM • Black & Decker... • Answered on May 08, 2014
0answers
0answers
0answers
Black & Decker SpaceMaker ODC325 Coffee Maker Logo
109 questions posted
Top Black & Decker Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Black & Decker Coffee Makers & Espresso...
  • Black & Decker Coffee Makers & Espresso...
Most Popular Question
odc325 removed
  • Coffee Makers & Espresso Machines
