20 Most Recent
Mowtownusa Snow Thrower Starter Switch for Toro S-200 and S-620 units # 29-5560 40-594 Questions & Answers
If you put straight gas in a two cycle snow
Yes, right after the piston seizes in the cylinder. If the motor is still running but doesn't have a lot of power and smokes a lot, you are mixing too much oil in your gas. You should go for a 50 to 1 mix. Read the label on the two cycle oil bottle for the proper amount to use in your gas for this ratio.
Snow blower won't start
just take off the AIR filter and thar is a Big Hole thar spray sum starte fluid in the bigger hole and spray it for three sec then try an start it
