I have a problem with
There is a short. The timer mechanism is mechanical, so the problem is not failed electronics.
The WH21 is for 240 volt circuits, so it has 2 hot wires and 1 ground from the breaker box. Only one hot line to the water heater is turned off, but both lines are attached to screw terminals at timer.
To see if the problem is a shorted element or shorted wire in water heater, disconnect hot leads to water heater one at a time, and then test. Then disconnect ground wire from water heater and test again. Then disconnect all wires to water heater, and test again.
If the problem is in the water heater, search for troubleshooting steps on internet. Focus on testing elements.
If the problem is not in the water heater, then a frayed wire on back of timer is next checkpoint. The timer motor is the final suspect. You can detach the timer motor from the housing, and test for stray voltage. Intermatic WH21 is inexpensive to replace.
8/26/2010 1:59:59 AM •
Electric...
Answered
on Aug 26, 2010
