20 Most Recent Amerec ON/OFF NON-THERMOSTATIC CONTROL R30K-ORB Questions & Answers
I have a Lithonia dusk to dawn flood light that's brand new there's also an on off switch. What does the on off switch control and for dusk to dawn should it be on or off?
  • When the switch is ON, the light operates in dusk-to-dawn mode. In this mode, the light automatically turns on at sunset and turns off at sunrise. When the switch is off, the light stays off.
4/18/2024 7:13:42 PM • Hardware &... • Answered on Apr 18, 2024
2answers
Grasslin QE7+ water heating timer dial problem
motor or gear failure
3/12/2024 10:39:33 AM • Hardware &... • Answered on Mar 12, 2024
Electrolux KOAAS31WX oven timer has maximum 20 minutes.
It sounds like the button contacts aren't making good contact. If you can get behind them you can spray them with electrical switch cleaner. ..
3/2/2024 6:36:01 AM • Hardware &... • Answered on Mar 02, 2024
How do I reset the ellis geyser timer to save electricity
Press P (program )on the timer and display will show then change the desired day, time and minute using the D+, H+ and M+ buttons. Press P again to set up another program and repeat the second step as above
2/26/2024 7:44:48 AM • Hardware &... • Answered on Feb 26, 2024
How do I program outdoor timer model 28486
Clear memory by pushing the reset button on the timer then reprogram using your current schedule when you want the timer to go off/on. Use the day and clock buttons for this then press enter
2/26/2024 7:35:43 AM • Hardware &... • Answered on Feb 26, 2024
Should the utiletech 24 hour manual timer make a humming noise while on?
No, the timer should not make any noise. The noise should be a result of loose connections which cause arcing, which can make a humming or buzzing sound. If you find that you still notice the sound, even when the main breaker is off then the problem is not electrical in nature.
2/26/2024 5:38:54 AM • Hardware &... • Answered on Feb 26, 2024
Micromark MM 9565 Timer. How to set up the timerMM9565micro Mark timer
Question edited for clarity and add a header in order with spaces and CAPS. It appears Micromark got out or the timer business. There is a similar one in another Fixya post, and a link to them. https://www.google.com/search?q=Micromark+MM+9565+timer ..
2/19/2024 10:55:33 PM • Hardware &... • Answered on Feb 19, 2024
How to turn water heating temperature up?
2/18/2024 9:47:44 PM • Hardware &... • Answered on Feb 18, 2024
How do I stop the timer on OXO digital timer # 1127980?
Manual
Instruction Insert
OXO https://www.oxo.com > wysiwyg > PDF_Files PDF The clock is set. • To set timer, press any button to enter timer mode. A timer icon will appear on the LCD screen. Press the and buttons to set the timer. 1 page ..
1/31/2024 2:06:27 AM • Hardware &... • Answered on Jan 31, 2024
2answers
I punched a fist size hole in the frame of bedroom door. How do i fix
Bondo it there is a wood bondo you could get or just use auto body works fine too
1/25/2024 2:59:22 PM • Hardware &... • Answered on Jan 25, 2024
I need a manual for CRMC-A310JBEO For Sharp Air Conditioner Remote Control
The Sharp Air Conditioner Remote Control CRMC-A310JBEO comes with two timer-related functions: TIMER ON and TIMER OFF. To set the timer on the remote control, press the Timer button, then use the Temp + or Temp - buttons to set the desired time. Wait 3 seconds, then the timer function will be activated. You can turn off either function by setting its timer to "0.0h".
1/24/2024 8:44:06 AM • Hardware &... • Answered on Jan 24, 2024
Lihom rice cooker manual english
You did not mention the model number. Anyway see this manual. It will help. CJH-PC1000_ENG.indd (cuchenamerica.com)
1/9/2024 8:54:26 AM • Hardware &... • Answered on Jan 09, 2024
Grasslin logica 500 instructions
1/9/2024 7:01:56 AM • Hardware &... • Answered on Jan 09, 2024
Stanley ET 380 C operating manual
Did you manage to find one ? Im also looking for a manual for the ET380C. Would appreciate any advice
1/8/2024 1:59:12 PM • Hardware &... • Answered on Jan 08, 2024
Aube TH132 A Thermostat. I can no longer see the temperature setting, it flickers very vaguely for a short time.
Try a Power Reset. Disconnect all mains power to it for 15 minutes, press and hold any button for 1 minute. Reconnect the power. If that doesn't fix it, the thermostat has failed and you need a new one. Most have backup batteries that can cause the issue you are seeing, but the manual doesn't mention anything about batteries in the base unit.
Aube Technologies TH132 A/F/AF Owner's Manual
ManualsLib https://www.manualslib.com > ... > Thermostat View and Download Aube Technologies TH132 A/F/AF owner's manual online. Aube Technologies Control Module Owner's Guide. TH132 A/F/AF thermostat pdf manual ... ..
1/6/2024 7:19:09 PM • Hardware &... • Answered on Jan 06, 2024
2answers
How do I program a Noma timer model 052-8835-2
https://sites.google.com/site/dyiu22/home/noma Quoting from web link:
NOMA
125V AC / 60 Hz OUTDOOR DIGITAL BLOCK HEATER TIMER 052-8835-2 Instructions Plug timer into grounded outlet
To Set the Current Time: Press the HOUR button as many times as necessary to advance the display the correct time. Note, the time can only be set in 30 minute intervals. The LED display will display the hour (1-12) and on the half hour a light will illuminate in the upper right corner, next to the number 30. To change from AM to PM toggle 24 times, a dot will illuminate in the lower right corner of the display next to the letters PM.
To Program the Timer: Press the PROGRAM button once, the letter P will flash. Press the HOUR button to set the ON time. Press the HOUR button to set the ON time. Press the PROGRAM button again, the letter E will flash. Press the HOUR button to set the OFF time. Press the PROGRAM button to exit program setting mode. Press the HOUR button to review the ON/OFF setting.
To Connect/Operate the Timer: Plug device in to the timer and turn the device on. To Revise the ON/OFF Setting: Unplug the timer and plug it back in. Repeat the programming steps above. To Override the Timer: Press the PROGRAM button if you want the device to turn on before the preset time, but note the device will turn off at the preset time. For example, if the preset ON/OFF period is 3 pm - 4 pm, users can manually press PROGRAM to turn the device on at 2 PM, the timer will keep running until the preset off time at 4 pm. Suitable for use with outdoor appliances. Raintight when mounted vertically with the receptacle facing downward. Use a three-conductor GFCI protected outlet. Do not immerse in water. DO NOT EXCEED RATED CAPACITY. Not for permanent installation. Do not install or use this product for more than a 90-day period per year.
NOMA Dennis
12/29/2023 1:43:11 AM • Hardware &... • Answered on Dec 29, 2023
Shopcraft wood lathe model #T6750-83A Manuel
Yeah thats right
12/27/2023 4:16:04 AM • Hardware &... • Answered on Dec 27, 2023
My T19 Kingshield automatic timer is clicking on and off. Kindly advise how to stop this happening.
Contact them for a free replacement. But first press and hold the Reset Button on upper right. https://images-na.ssl-images-amazon.com/images/I/71OhENnuRdL.pdf ..
12/27/2023 12:32:02 AM • Hardware &... • Answered on Dec 27, 2023
Amerec ON/OFF NON-THERMOSTATIC CONTROL R30K-ORB Logo
0 questions posted
Top Amerec Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you an Amerec Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Amerec Hardware & Accessories
Most Popular Question
sauna wont get hot enough
  • Hardware & Accessories
