20 Most Recent
Emerson EWR20V5 DVD Recorder/VHS VCR Combo - Salvage/Replacement Parts Only Questions & Answers
How to setup a onn remote control to a emerson TV
1. Turn on your Emerson TV.
2. Consult the ONN remote manual for Emerson TV codes.
3. Press TV on the ONN remote.
4. Enter the correct code.
5. Test remote functions.
- If unsuccessful, try code search or auto-programming.
6. Ensure compatibility.
1/8/2024 3:58:07 PM •
Emerson...
Answered
on Jan 08, 2024
My Emerson DVD player says Disc Error Playback feature may not be available on this disc
The error message "Disc Error Playback feature may not be available on this disc" can have a few different causes. Here are some of the most common:
- The disc is not compatible with the DVD player. Some DVD players are only compatible with certain regions or formats of discs. If the disc you are trying to play is not compatible with your DVD player, you will get this error message.
- The disc is damaged. If the disc is scratched, dirty, or otherwise damaged, it may not be able to be read by the DVD player.
- The DVD player is faulty. If the DVD player is faulty, it may not be able to read discs correctly.
Here are some things you can try to fix the problem:
- Try playing the disc in another DVD player. If the disc plays in another DVD player, then the problem is with your DVD player.
- Clean the disc. Use a soft, dry cloth to clean the disc. Be careful not to scratch the disc.
- Format the disc. If the disc is formatted for a different region or format, you may need to format it for your DVD player.
- Reset the DVD player. If the DVD player is faulty, you may need to reset it.
If you have tried all of these things and you are still getting the error message, then you may need to replace the DVD player.
7/6/2023 7:52:52 PM •
Emerson...
Answered
on Jul 06, 2023
Anyone know the start and run cap values on an Emerson LR63596 model T63XWBSS1486, labels have deteriorated
The capacitor values for the Emerson LR63596 model T63XWBSS1486 motor will depend on the specific application and the motor's specifications. Without more information about the motor's voltage, horsepower, and other details, it's difficult to give a precise answer.
However, as a general rule, the capacitor values for single-phase AC motors like the Emerson LR63596 typically range from around 5-80 microfarads (µF) for the start capacitor, and 5-100 µF for the run capacitor.
That being said, it's important to note that the specific capacitor values required for your motor may be different, and using the wrong values could cause damage to the motor or affect its performance. Therefore, it's recommended to consult the motor's documentation or a qualified technician to determine the correct capacitor values for your specific application.
6/27/2023 5:47:05 PM •
Emerson...
Answered
on Jun 27, 2023
Where are fuses on a Emerson TV model # LD190EM2
Fuses are solder in, and chances of a fuse blowing without other bad components are slim, take it in for service or better yet buy a new TV unless you have a multimeter and know how to trouble shoot a tv
6/25/2023 4:56:05 PM •
Emerson...
Answered
on Jun 25, 2023
Emerson LTDN42V68US television will not power on. The light just blinks red continuously ..
What's happening with your TV is the backlight inverter is sensing over current and shutting the entire power supply down (excluding the standby supply) this gives the 1 blink code. Reason for over current is open circuit in the LED backlights, you will need to replace the lamps to fix the issue, there is about a 2% chance of it being a faulty power supply but in most cases it's the lamps. This is common on most Funai brand sets.
4/8/2023 3:47:08 PM •
Emerson...
Answered
on Apr 08, 2023
How come my Daewoo remote 97p1803700 will not work anymore?
The issue with your Daewoo remote 97p1803700 may be due to battery depletion, broken buttons, or internal damage. To resolve the issue, you could try changing the batteries, checking the buttons for any physical damage, and cleaning the interior of the remote control. If these steps do not resolve the issue, you may need to take the remote control to a professional repair service. As for the eject button, the functionality may be limited by the remote control model and the device it is controlling. It may not be possible to add an eject button to your current remote control, but you could look for alternative remote control models that offer the eject button
2/3/2023 5:31:22 PM •
Emerson...
Answered
on Feb 03, 2023
Connect to Emerson tv to remote?
To connect your Emerson TV to a remote control, you can follow these steps:
- Make sure the batteries are properly inserted in the remote control.
- Turn on the TV.
- Locate the remote control sensor on the TV.
- Point the remote control directly at the sensor and press any button to see if the remote is working.
- If the remote is not working, try changing the batteries or resetting the remote control.
If you are still having trouble connecting the remote to your Emerson TV, you may need to consult the TV's manual or contact the manufacturer for further assistance.
2/1/2023 3:48:51 PM •
Emerson...
Answered
on Feb 01, 2023
How to change the resolution on a Emerson tv?
What is your video source? I have only seen this message on TVs when a connected set top box was set to an unusable resolution. (For example, a set top box set to progressive scan when the TV can only handle interlaced scan. For a full HD video source these would be labeled 1080i or 1080p. There might be other characters in the settings menu list, depending on the source.)
When my cable box did this when using an HDMI cable, the simplest solution for me was to connect the cable box to the TV using a RF cable. Both the set top box and the TV had RF connections. My TV has both a menu button and a source button on the front panel. I set the source to TV. Then I was able to tune to channel 3; channel 4 can work. (Scanning for channels from the on-screen menu was available without a remote.) Then I used the set top box's remote to access that menu. Then I got to Settings > Hardware Settings > Video. Then I could change the output video resolution for HDMI back to 1080i.
This is harder with some of the streaming devices with only an HDMI connection. I hope this helps. Please add a comment to let me know which model TV and device have the resolution mismatch for additional steps to resolve the problem.
1/31/2023 2:04:32 AM •
Emerson...
Answered
on Jan 31, 2023
