20 Most Recent
American Standard 4251 'The Standard Collection' Bottom Mount Kitchen Fauce Questions & Answers
I have the AS 4251
You are going to have to take the handles off and clean out the ports and valves. Evidently something is stuck under the washers. Turn off the water underneath the sink, remove the handles, just as if you were going to replace washers. Also look into the faucet inlet where the water hoses connect. Probably sediment has gotten into the mechanism.
6/23/2011 9:21:35 PM •
American...
Answered
on Jun 23, 2011
I have an American Standard
Contact A/S via web site they will probably send you a new diverter free if you raise enough stink about having this problem and you would just buy another brand faucet.
6/14/2011 1:37:36 AM •
American...
Answered
on Jun 14, 2011
I f like most faucets it will have a aerator its at the end of the spout unscrew & clean...that should do the trick ';';';
5/5/2011 10:32:00 PM •
American...
Answered
on May 05, 2011
Clogged sinks and toilets
Never use Draino on a toilet. All pipe cleaning liquids are not really a solution, just a temporary fix.
Since you said that the slow draining is associated with both the toilets and the sinks then I am almost certain that you have a venting issue.
Imagine a drinking straw.....now if you hold your thumb on the end of the straw and bring it up abouve the water level water remains in the straw. This is because air can't get in to replace the water. When your finger is removed then the water flows freely.
As with the straw, your plumbing must also breath. I would bet that one or more vents that are on your roof have become clogged with debrise. Squirrels love to throw nuts and stuff down there to build their nests upon.
Climb up there (safety is a priority) and try running a snake (~$10 at lowes) and see if you hit any obstruction. If so, use the snake to dislodge it.
If you would like, pour water down the vents either by hose or bucket and see if the water backs up. If it does then you have a clog. You can also use the water to try to clear the clog.
Thanks.
4/6/2022 3:13:10 PM •
American...
Answered
on Apr 06, 2022
Speed connect drain will not go down completely
Make sure that the compression nut is not too tight where it could bind up the plunger rod. I'm sure you have probably gotten up under to see if it is hitting anything. Also, make sure that the lift rod is adjusted correctly. I am leaning more towards the unit being bound up some how.
12/10/2018 11:24:22 PM •
American...
Answered
on Dec 10, 2018
American standard 2k-2h still leaks after replaceing sem and nut
Did you replace or reface the seat (the surface in the bottom of the faucet body where the stem's washer "seats" itself to shut off the flow of water? There are special tools for removing the old seats and installing new ones (available from professional plumbing suppliers), or you may be able to renew the seat's surface with a special tool called a seat surfacer.
4/13/2018 10:58:01 PM •
American...
Answered
on Apr 13, 2018
How do i remove bathroom sink drain plug?
If by push pull you mean there is a knob and rod that you use to raise and lower the plug. Look under the sink for a rod extending perpendicular to pipe it will be about 8" long and attach to a linking bar below he push pull rod. Typically there is a small retaining nut that seats around a ball seal on this rod that secures it to the tail piece dropping from sink. Unscrew the retaining nut, slide the rod out and then lift out the plug. You will notice a ring on lower end of the plug piece that you will need to insert the rod thru when reassembling. If you are referring to a fixed twist and drop plug Open it and there will be a set screw on a flat face in the stem portion under the cap. It's usually small straight slot screw but may also be a hex head slot Loosen that screw and the plug will lift off a center peg in the drain assembly.
1/12/2018 10:02:19 PM •
American...
Answered
on Jan 12, 2018
How to replace the trap for kitchen sink..there is
open to drain pipes. remove the collars that hold trap on, sometimes you may need pliers or a pipe wrench to remove.install is reverse of removal the trap is there to contain the gases in drain pipe. if no trap. you will smell sewer water all the time. 1-1/4 for bathroom drains and 1-1/2 for kitchen sink drain.
9/13/2017 12:13:07 AM •
American...
Answered
on Sep 13, 2017
How to fix leaky American Standard single faucet kitchen sink
The A-S single lever kitch faucet is terrible. If it is the one I think it is, then it has three screws that mount the cartridge down into the faucet body.If these are not torqued perfectly evenly, the faucet leaks. I suggest getting a Moen to replace it.
5/20/2017 3:21:33 AM •
American...
Answered
on May 20, 2017
Odor coming from water in my home.
I have had this for no reason it smelt as you say The only thing is you may have disturbed the pipes Odd I know drives you mad , As you say a softener would do the trick . or maybe if your on a well , A well flush but they cost .
3/21/2017 9:59:21 PM •
American...
Answered
on Mar 21, 2017
