20 Most Recent Delta Faucet Delta 470-BL-DST Signature Single Handle Pull-Out Kitchen Faucet With Spray Questions & Answers
Delta 470 trying to remove metal pull out spray wand but it gets stuck when trying to remove and replace
Are you trying to just replace the sprayer? I replaced the whole unit so cannot help with just the sprayer.
6/9/2014 5:26:17 AM • Delta Faucet... • Answered on Jun 09, 2014
2answers
Single handel kitchen faucet: Over time the
shut-off the water, pull the handle and the spout. change the 2 "O"ring and make sure the spout body has no dirt in them. apply some the plumbing grease bewteen the spout body. put everything back.
4/29/2011 11:40:00 PM • Delta Faucet... • Answered on Apr 29, 2011
I think our Signature faucet
these are really well designed.take a flashlight and go under and look up.most leaks come from stop valves.if the hose is leaking,you can change o rings.oooooor you might have a bad hose.delta will be happy to replace it. I've found there customer service easy to deal with.
1/29/2011 1:22:14 AM • Delta Faucet... • Answered on Jan 29, 2011
I"m removing and replacing a
Since you are replacing the Delta Faucet Delta 470-BL-DST Signature Single Handle Pull-Out Kitchen Faucet With Spray faucet, bend the water supply lines out of the way, and then use a standard basin wrench to remove the nut.
1/25/2011 12:31:31 PM • Delta Faucet... • Answered on Jan 25, 2011
After replacing seats & springs,
need to put in little round ball back.. the right way..make sure ball is in right before putting hold down holding piece w notch in it
11/22/2010 1:56:55 AM • Delta Faucet... • Answered on Nov 22, 2010
The O rings need to
handle should have an allen screw rite under the handle coverd by a little cap mite have red and blue..shouldnt have to take hose off but that just snaps off from under sink.
11/21/2010 8:06:11 PM • Delta Faucet... • Answered on Nov 21, 2010
Faucet continually drips in off position
If its leaking when faucet is in off position than seats and springs will need to be replaced. To do this shut off water to faucet both hot and cold. The handle is held on by a allen head set screw on the back side of handle . Loosen set screw and carefully remove handle,this make take alittle persuasion but don't force it. Carefully rock back and forth and tap lightly on base of handle .When you get handle off the round cap assembly will need to be removed,it has serrations at bottom to grip it withchannel lock pliers. You need to be very careful here and not use too much force because if you do you will twist copper fittings inside of faucet and ruin it. If it does not come loose fairly easily by turning counterclockwise you can use a mini hack saw or just hacksaw blade and carefully split cap on back side. Go slow stopping often to make sure you don't go any deeper then absouletly neccesary. If you slightly mark retaining threads it's not terrible. Most of the cut is not to bad because all parts immediatly underneath are easily replaced. When you get almost all the way thru take a large blade screwdriver insert in slot you have cut and twist back and forth to break cap the least of the way. Cap will be easy to remove now,take it off and pull out control ball along withrubber seal. There will be a small round rubber seat on bottom,one for hot and one for cold remove them and springs underneath them.Replace all parts that may have been damaged.needless to say you will need cap and seat and springs at the least.Repair kits are redily available just follow instruction and you should be fine.I know it's a pain but if you take your time you can save a good faucet. Hope this helps. Thanks
11/11/2010 4:37:34 PM • Delta Faucet... • Answered on Nov 11, 2010
Facet still leaking after replacing the RP4993G
Make sure the area below where you replaced that part is free of scale and is not damaged in any way. Scuffs, scale and dirt will caused your leaking.
9/13/2010 4:00:20 AM • Delta Faucet... • Answered on Sep 13, 2010
I pulled the sprayer out
The flex hose for the sprayer can be seen under the sink. It may be hung up on a pipe or other object. As long as there is nothing broken on the sprayer you should be able to ease it back into place by gently applying a "pulling" pressure on the sprayer hose under the sink.
9/12/2010 10:20:24 PM • Delta Faucet... • Answered on Sep 12, 2010
2answers
Need
You should be able to find them at lowes or any other hardware store.
5/14/2010 12:04:32 PM • Delta Faucet... • Answered on May 14, 2010
Very low pressure
To get full pressure you need to pull the wand away from the base. Then remove the wand from the hose becareful not to loose the washer. When the wand is removed look down the wand you will see a plastic part. That plastic part is a flow restrict-er. You need to put a screw in the restrict-er and pull it out. When it is out put wand back on the hose then you will have full water pressure.
1/16/2010 6:59:44 AM • Delta Faucet... • Answered on Jan 16, 2010
I am trying to find some faucets that will not freeze
GO TO MORRISON SUPPLY WEBSITE
12/29/2009 8:20:11 PM • Delta Faucet... • Answered on Dec 29, 2009
Two people can not shower at the same time because
Hello.. The problem you are having is common. there are only two causes. One is that the water pipes in the house are old and partially filled with scale and such. The other, and more common problem is that the house is plumbed entirely with one size of pipe, usually 1/2 inch pipe. Houses that do not have this problem use a larger size pipe to carry the water around the house, say 3/4 inch and then only go down to 1/2 inch when they are about to feed a faucet or a toilet. There is no inexpensive fix to this problem. The only fix is to replumb the main lines in the house with a larger size pipe and then go down to the 1/2 inch size when you are near the faucet or toilet.
12/2/2009 8:11:18 PM • Delta Faucet... • Answered on Dec 02, 2009
I just put in a new faucet and I can't tighten the
You need to puechase a basin wrench
11/28/2009 4:22:31 AM • Delta Faucet... • Answered on Nov 28, 2009
I have a delta pull-out sprayer that has separated
You need to have a second person feed the hose back up so you can grab it and reconnect
11/15/2009 4:42:10 AM • Delta Faucet... • Answered on Nov 15, 2009
3answers
My Delta single handle kitchen faucet with pull
You will need someone to help you hold faucet body and assembly to sink, so that you can tighten up rod from under sink without it getting bound.
9/18/2009 3:41:16 AM • Delta Faucet... • Answered on Sep 18, 2009
Delta Kitchen Single Faucet 470 suddenly would not give water
Debris in the valve is a fairly common cause for stopping water flow in single lever valves. You can first check the aereator and remove any debris that may be there at the faucet itself. Then you can try to remove the ball at the control lever. You have to be careful and make sure that you do not drop any parts. Especially if this is a recent installation, you may find a large piece of something there.
6/28/2009 4:43:49 PM • Delta Faucet... • Answered on Jun 28, 2009
Replace the seal on the 470 DST single handle pull out faucet
Turn the water off at the faucet, remove the handle and the retaining nut that is apart of the trim. You will see where you can use a wrench to remove it. The ball assembly will come right out and you can replace the washers right below it. Put it back together and if needed, tighten the tension ring that is on the retaining nut (usually grey or white in color) so it won't leak water around the ball stem. Good luck.
4/3/2009 12:51:02 AM • Delta Faucet... • Answered on Apr 03, 2009
How to remove stuck cap for delta single handle faucet
Take a rag and put over nut then tap all-around nut. Then use your hand to try and unscrew. A strap wrench is the best tool for taking these off. I have been to so many of these where the homeowners have used channel locks or pipe wrenches and scarred up nut or broken off copper tubes. They seem amazed when i tap it a few times and remove it with my hands. Channel locks and pipe wrenches actually cause the nut to bind when using this much force. Make sure you loosen the plastic retainer on top of the nut first.For more details about single faucet repair
8/24/2021 4:21:14 AM • Delta Faucet... • Answered on Aug 24, 2021
The single handle Delta kitchen
remove the handle that turns water on and off , usually an allen wrench lift and swing back and forth at the same time. the spigot should come off. replace o rings lubricate with silicone grease reinstall spigot and handle
11/16/2017 4:52:11 PM • Delta Faucet... • Answered on Nov 16, 2017
Delta Faucet Delta 470-BL-DST Signature Single Handle Pull-Out Kitchen Faucet With Spray Logo
Popular Tags
38 questions posted
Top Delta Faucet Plumbing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
View Most Popular
  • Delta Faucet Plumbing
Most Popular Question
think our signature faucet
  • Plumbing
