20 Most Recent Nikon Inc Nikon Coolpix S9050 - digital camera Questions & Answers
Date stamp coolpix s9050
If you want a date stamp on photos go to Menu and turn on Date stamp after setting proper date under time and date setting under Menu. Rich
12/27/2014 7:08:30 PM • Nikon Inc Nikon... • Answered on Dec 27, 2014
Battery will not charge
Check battery with voltage tester or try a new battery which are cheap on ebay by the way. Rich
12/27/2014 7:05:47 PM • Nikon Inc Nikon... • Answered on Dec 27, 2014
My camera will no longer save to my SD card
Did you check that is connected to card properly and pull card out and push back in several times. Sometimes cards or pins that connect cards get corroded especially in damp weather. Also did you try another SD card to see if it will save to another card. Rich
12/27/2014 7:05:01 PM • Nikon Inc Nikon... • Answered on Dec 27, 2014
2answers
My pictures are constantly coming out blury...I have it on sport mode, what else should I be checking.
Blur is usually caused by one the following problems. 1) Camera is unable to focus so the shot is out of focus. 2) The hand shakes during a shot that has a longer exposure (shutter speed) and 3) There is not enough light so the camera holds the shutter OPEN (seeing) while to subject is moving. In most cases you will have few problems when you have plenty of light. Many indoor areas when you zoom in have too little light to take a quick non blurry photo. Flash can freeze motion. The flsh is quick and it is like a strobe freezing action. A tripod prevents camera shake.
11/25/2014 8:32:53 PM • Nikon Inc Nikon... • Answered on Nov 25, 2014
Camera will not turn on and tried to recharge
Many camera you can also plug into USB port on computer (try this as alternative). Inspect the battery if it is dirty or has something on contacts it may not work. If the battery is super dead it will never work in the camera. There are ways for a technical person to put a little voltage on the battery to bring it back from dead. It is not worth buying a new battery until you can turn the unit on.
11/25/2014 7:55:53 PM • Nikon Inc Nikon... • Answered on Nov 25, 2014
When I look at the subject everything looks ok but after the picture is taken some times it looks out of focus
You need to remember to allow the camera time to focus. Press half way down on the shutter. That causes the camera's focusing system to start. Then, after about a second continue pressing the shutter for the image capture.
7/17/2014 2:46:04 PM • Nikon Inc Nikon... • Answered on Jul 17, 2014
I have nikon coolpix s9050 camera when i click picture.screen shows this card cannot be read
Try a different/new brand of card or take the card to any camera store and ask them to try to load the card into one of their cameras for you, it's an easy way to test the card. Many cheeper cards don't always work with all cameras.
11/10/2013 9:18:34 AM • Nikon Inc Nikon... • Answered on Nov 10, 2013
Digital Harinezumi 2++ won't turn on
It is not well thought of and considered a toy. https://www.google.com/search?q=digital+harinezumi+2+won%27t+turn+on ..
4/20/2024 12:20:14 PM • Cameras • Answered on Apr 20, 2024
My open view is not showing any pictures but showing information about programs playing what might be the problem
Some steps you can try: Check Picture Location: Ensure that the pictures you want to view are in the same folder location. Sometimes, if the images are scattered across different folders, they may not appear correctly in the photo viewer. Repair or Reset the Photo App (for Windows 11): Go to Settings > Apps > Photo. Click on Advanced options. Choose either Repair or Reset to address any potential issues with the Photo app. Enable Thumbnail Previews (for Windows 10): Open File Explorer Options: Type "file explorer options" in the Windows search bar and select the first result. Switch to the View tab. Ensure that the option "Always show icons, never thumbnails" is unchecked. Click Apply and then OK to save the changes. That is about all I can offer. If you repost, include brand and model.
4/19/2024 8:18:20 PM • Cameras • Answered on Apr 19, 2024
2answers
I forgot the combination to my safe can i reset it
limited info generic answer notify manufacturer or locksmith for assistance
4/16/2024 7:20:17 PM • Cameras • Answered on Apr 16, 2024
Activition code digital tv 2050
Free version does not require activation, but unsure if that will work for you. Web site specifically states there is not any activation code and not supported. All of its software is "free, freeware, shareware, full version, trial, demo or open-source" https://www.download.hr/software-digital-tv-2050.html
4/15/2024 9:02:35 PM • Cameras • Answered on Apr 15, 2024
INTERNAL ERROR FREEGROMRIGHT SIZE 1431655766
I don't see anything that resembles 'make model (what it is)'. You posted to the category Cameras? https://www.google.com/search?q=FREEGROMRIGHT+SIZE+1431655766 ..
4/5/2024 1:31:05 AM • Cameras • Answered on Apr 05, 2024
2answers
Where can I get Manual for novar ed&s wireless colour camera
if you purchased the camera from a retailer or reseller, they may have a copy of the manual available.
4/4/2024 12:04:13 AM • Cameras • Answered on Apr 04, 2024
How do you turn on Digivue1.3? Has new batteries and used a while ago but pressing 2 button (Mode, Set) do nothing.
This is going to take patience and maybe the user guide. To turn on the Digivue 1.3, follow these steps: Connect to Your PC: Connect the standard USB cable (supplied) to a free USB socket on your PC. The end of the USB cable should be connected to the socket on the back of the USB digidock. Important: Do not connect any of the cabling provided with the Digivue before commencing the software installation. Install DigiConnect Windows® Software: Insert your Digivue into the docking station. If you are connecting for the first time, a Red LED will display in the Activity Window of the Digivue. Insert the CD provided into your optical disk drive. It will run automatically, and a dialog box will appear. If the autorun feature is disabled on your system, browse to the disk using Windows® Explorer and double-click Setup.exe. If you have a multilingual version of Digiconnect, you will be prompted for your language. Select from the list and click "Next." Accept the terms in the License Agreement and proceed with the installation. Choose the folder for software installation (default is the standard location for Windows® programs). Click "Install" to begin the installation. Leave the box labeled "Launch DigiConnect" ticked and click "Finish." Wait for the Red LED: Wait until a RED LED appears in the activity window of the Digivue. You may now proceed with the next steps. If you encounter any issues during this process, refer to the detailed instructions in the Digivue User Guide on page 9
4/1/2024 1:04:02 PM • Cameras • Answered on Apr 01, 2024
Hello, I would like to know how to solve an error called "ALLARME" "sicur camera"??
Reboot everything. If that doesn't work, Maker Support.
SICUR SERVICE ITALIA
SICUR SERVICE ITALIA https://www.sicurserviceitalia.it ·Translate this page 1.3 MP Camera · 2 Mega Pixel Camera · 3 Mega Pixel Camera · 4 Mega Pixel IR Camera · 5 Mega Pixel IR Camera · 12 Mega Pixel Camera · Speed Dome da esterno ... ..
3/15/2024 2:12:47 PM • Cameras • Answered on Mar 15, 2024
2answers
Which is the best weding photographer in ernakulam
Here are some highly regarded wedding photographers in Ernakulam, Kerala:
  1. Maks Wedding Photography:
    • Located inChelad, Kothamangalam, Kerala.
    • Specializes inwedding photography and videography.
    • Contact:099478 23133.
    • Facebook Page
  2. Lumiere Wedding Company:
    • Based in Ernakulam, Kerala.
    • Their crew beautifully captures emotions during the D-day, creating elegant pictures that will remain etched in your heart forever.
    • They cover weddings not only in Ernakulam but also in UAE, Malaysia, and other parts of the globe.
    • Contact:099951 48014.
    • Website
  3. Euforia Wedding Photography:
    • Located atUzhinjelil Tower, Convent Rd, Ponnurunni, Vyttila, Kochi, Kerala.
    • Offers candid and artful wedding photography packages.
    • Cherish the vibrant traditions and colors of your Kerala wedding with their skilled team.
    • Contact:090481 90403.
    • Website
  4. Dakshin Wedding Services:
    • Exclusive wedding photography and videography company covering events across South India.
    • Address:Js 5, 5th Floor, Heavenly Plaza, Kakkanad, Edappally, Civil Line Road, Ernakulam, Kerala.
    • Contact:070123 90551.
    • More Information
Remember to explore their portfolios, discuss your preferences, and find the photographer whose style resonates with your vision for capturing your special day! These companies use teams. It is difficult to pick out an individual photographer but perhaps you might find what you are looking for at the Lumiere Wedding Company. That company stands out among the four I mentioned.
3/15/2024 10:38:43 AM • Cameras • Answered on Mar 15, 2024
Hi, I am in Dubai,I
FUJIFILM MIDDLE EAST FZE [Subsidiary] Business Field (s): Digital Cameras
Address: P.O. Box 17212, R/A08, HB03, Jebel Ali, Dubai, U.A.E.
Tel: 971-4-883-9990
GRAND STORES [Distributor] Business Field (s): Photographic Film and Paper, Film Cameras, Digital Cameras, Digital Printers, Minilab Systems, Medical Systems
Address: Saleh Mohammed Bin, Lahej Building, Al Garhood, P.O. Box 2144, Deira, Dubai, U.A.E.
Tel: 971-4-2-823700
Dynagraph For Printing Industry [Distributor] Business Field (s): Graphic Systems
Address: Al Quoz Industrial Area, Sultan Al Suwaidi Building, Office No.1, Dubai, U.A.E.
Website:
3/14/2024 5:17:47 AM • Cameras • Answered on Mar 14, 2024
Nikon Inc Nikon Coolpix S9050 - digital camera Logo
8 questions posted
Top Nikon Inc Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Nikon Inc Camera Expert? Answer questions, earn points and help others
View Most Popular
Nikon Inc Cameras
  • Nikon Inc Cameras
Most Popular Question
pictures constantly coming out blury
  • Cameras
