20 Most Recent
Bosch Exxcel WFO 2465 Front Load Washer Questions & Answers
Front load washing machine would not spin now won't wash either.
Sounds like you have a broken belt or a bad motor. The easiest way to tell if the belt is bad is to reach inside the drum and turn it. If it turns very easily, you probably have a bad belt or something has caused the belt to jump off, such a s a loose pulley or bad bearing. If it feels like there is a good amount of resistance, or a kind of "winding up" noise, then the belt is still on and you likely have a bad motor. Also, you could just scoot the macine out, unplug it, and remove the back cover a look inside to see if the belt is still on the pulleys. Good Luck!
What is a plastic coupler
a piece of plastic that couples/connects two items together, think of it as a link in a chain.-each link couples to the nextA piece of material (plastic in your case) fabricated to affix one or more materials to another. Just about every coupler is fabricated for a specific application. Audio, video, various type hardware, plumbing etc if you need one it is likely you need an exact replacement but not always.... good luck
Got a Bosch WFO 2460,
there is a thermal cut out located in the windings on the motor you may have o hunt for this it has a wire going in and n out, you could short it out as a quick test if motor running....
Bosch Exxcel did not spin
Sorry but I do not have the decode for F18 for your particular machine but for similar models F18 indicates a 'pump/drain out time'. I would therefore suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
