20 Most Recent
Bosch HGS 255 Gas Kitchen Range Questions & Answers
My gas convection range bakes just fine but fan is
Chances it is a fan failure. Check the wired to the fan as well. If able, place 120 volts to the fan wires to see if the fan starts. If the fan works then it is not the fan. but the fan and the surrounding wires would be my first suspects.
Oven will not heat i set the temp , turn it on,
Hi
This means a
loose/broken wire on the oven temp sensor or the oven temp. sensor itself is
bad and should be replaced. To solve this issue test the oven temp. sensor, it
should read between 1080-1120 ohms, if the rating is more then that and the
door appears to be closing fine then it is the control board that is bad and
should be replaced. Hope this helps...please post back for further assistance.
Daniel
IGNITERS CONSTANTLEy CLICKING
It is because it is having it's path to ground interupted where it uses the flame as a path. It is fairly easy to fix just use a brass brush to clean the ignitor and the burner assembly (where the spark is going to) do it to all the burner you use monthly, for preventive maintenance.
