20 Most Recent Price Pfister Hanover 950-102S Soap & Lotion Dispenser - Stainless Questions & Answers
Price Pfister has a 800 number that you can call if you are having problems. If they can not fix it, they offer a life time warranty on most products that they make. They will usually send out a replacement for it if they can not solve your problem.
Price Pfister... | Answered on Aug 18, 2012
Best thing to do is contact Price Pfister directly. If there is a problem with the dispenser or there is a faulty part, they are usually pretty good about replacing their stuff at little or no cost to you, their customer.
Price Pfister... | Answered on Aug 23, 2010
Is the trap and drain not installed yet? If there is no plumbing to drain into then I would siphon or pump it out into buckets.
Price Pfister... | Answered on Jan 28, 2010
Does the tub spout water flow stop when the shower knob is pulled?
Was the systems pipping flushed before the shower head was installed?
It may be clogged, remove the shower head and then attempt to operate. If it is clogged you will see debris trapped in the screen at its connection point. The shower head can be disassembled - cleaned - reassembled
Is the shower head an adjustable type, that may be in the off position?
Good luck
Aduz
Price Pfister... | Answered on Mar 26, 2009
If you are installing a wax (doughnut) seal to connect the toilet to the main drain, then the wax ring should be big. It should 'squish' to seal correctly. You may not need it, but I've known plumbers to install two of the seals at once for extra gap-filling. Just install the seal, sit on the toilet to compress the seal into place and then install the bolts to the floor. Done!
Price Pfister... | Answered on Oct 23, 2017
you need a new tank kit, pick one up at your local Menards
Price Pfister... | Answered on Nov 19, 2014
I don't know your exact model but most faucets screen filter can be screwed off for cleaning or replacement. Remove the screen filter with a pair of pliers and a rag. Once you get it loose, you should be able to unscrew with your fingers. Put the rag around filter before putting the pliers on it to prevent gouges and deep scratches in the chrome. IF you have a dishwasher, you can clean the screen filter on top basket of dishwasher if you have one. IF the screen filter looks bad to you, just replace it. Go to any hardware store ,take the screen filter with you and get help finding the right one. Once you have a replacement, hand screw it back on as tight as you can. IF it still leaks , use the rag and pliers to tighten it just enough to stop the leak in the screw parts. Good luck.
Price Pfister... | Answered on Sep 01, 2014
Bear with me, please. Adjust the temp at the physical valve?
Interesting at the least. Never seen or heard of that. They come up with something new everyday. I'm going to follow this for my own benefit. Thank you. And good luck. - Ned
Price Pfister... | Answered on Jul 23, 2014
Price Pfister Hanover 950-102S Soap & Lotion Dispenser - Stainless Logo
Popular Tags
6 questions posted
Top Price Pfister Home Experts
Mike
jdthefixer
Are you a Price Pfister Home Expert? Answer questions, earn points and help others
View Most Popular
Price Pfister Home
  • Price Pfister Home
Most Popular Question
soap dispenser doesnt pump soap
  • Home
