20 Most Recent
Kocaso M1052S 10.1" Android 4.0 Tablet PC Questions & Answers
Customer service tablets
Try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before.
My charging doc has broken
The only way to repair would be to solder a new connector to the mainboard. It would be much cheaper to buy a new tablet.
It won't unlock i can't open the tablet
If you set a pass code (or pattern) that you cannot remember, please enter the wrong password (10-20 times) until you are prompted to sign in via your google account. Please note, this will only work if you have already setup your google account on the tablet. If you have not set up a Google (or Gmail) account on the tablet, you will have to perform a firmware install, which will revert the tablet back to factory settings.
Support Troubleshooting Guide
Tablet will not turn on
Kocaso m750
