20 Most Recent
Kocaso MID-M750B MID-M750B 7-Inch Tablet Black Questions & Answers
How do you set up the chargers
You plug the small plug of the USB cable (OTG) into the OTG socket.
You plug the large USB plug into the charger.
Plug the charger into the wall socket.
How do i transfer my kocaso tablet to a dell computer?
SImply use a data cable and connect from your tablet to your computer. If you have windows 7 or later it should autodetect and download the correct driver.
You may have to enable usb storage on your device, When you plug it in make sure it is on and it should prompt you.
Alternatively you can turn on usb debugging and install the Android SDK. Then use it to backup the entire tablet via adb.
Why cant i download whatsapp?
If it reports that it is not compatible, then the system will not allow your to download the app. There are may apps that behave like this.
Download firmware for m750b tablet
Be aware you need a working tablet to update. the program must be in working order and the processor must run. Once you start the upgrade, there is only a small routine running, to put the new program in the right place in the Flash memory. You don't get a second chance, if anything goes wrong, because even the routine to update can't be put in place or run.
An update is NEVER a solution for a bricked tablet.
Please check some forums what to do with your problem, but please don't brick the device with an update you can't get in place.
M760 patten unlock
If you set a pass code (or pattern) that you cannot remember, please enter the wrong password (10-20 times) until you are prompted to sign in via your google account. Please note, this will only work if you have already setup your google account on the tablet. If you have not set up a Google (or Gmail) account on the tablet, you will have to perform a firmware install, which will revert the tablet back to factory settings.
Support Troubleshooting Guide
Touchscreen cracked half sreen doesnt work
The manufacturer does not cover accidental damage, but we instituted a program where you can turn your tablet with a cracked screen in (as long as you are still within your warranty period. The nice thing about this is that not only are we the least expensive route when you crack your screen, but you do not have to wait for repairs. We simply send a replacement once we receive your damaged one.
Contact us at
Company Contact us to setup your request.
The front srceen wont unlock
Try unlocking with your Email Account. or the Security Answer that possibly you know.
if you have a back-up of your data then i suggest you to re-install your Operating System (Most Economic Plan)
If all else fails, please visit sites like Mobile Madness, it might cost about $10-$15 to unlock.
