20 Most Recent Caroma 270W-RF Reflection Round Front Dual Flush Toilet - White Questions & Answers
Despite fitting a new washer kit to an old style
I suppose you're talking about a toilet. One likely issue is the flapper valve ( if this has one). If no flapper then check whatever sealing mechanism is used to prevent water from entering the bowl when idle. Clean the sealing surfaces good. Make certain they are properly aligned.
9/4/2017 6:32:28 PM • Caroma 270W-RF ... • Answered on Sep 04, 2017
0answers
What is causing my toilet cistern to fill very slow?
The fill valve (operated by the float) may be clogged with sand or debris from inside the pipe. It's generally easier to replace a fill valve than it is to take it apart & clean it.
7/31/2014 10:21:16 PM • Caroma 270W-RF ... • Answered on Jul 31, 2014
0answers
My toliet keeps running. Have checked valves flap etc. I turned the water off , using the little toliet tap. Can I turn it on too much,making the pressure to high??
Replace the flapper. That is cheap to do. You can turn the water on near wide open And it should be ok. In other words, if you can't turn it on wide open, then something is wrong. I would just turn it on about 3/4.make sure your flat is not allowing the water to go over the top of the open tube.in the tank.
1/30/2013 3:04:41 AM • Caroma 270W-RF ... • Answered on Jan 30, 2013
The bowl doesn't flush from the front part
If a new toilet, the front holes may not have been cast correctly. If an older toilet it is likely mineral buildup has blocked those holes. A mittor and a coat hanger shoudl suffice to open the holes up, use the mirror to see under the rim lip and use the coat hanger to open the holes- you may need to use a larger clip instead depending on the size of the holes.
10/30/2012 9:38:06 PM • Caroma 270W-RF ... • Answered on Oct 30, 2012
How do I get the lid off a stylus toilet cistem
Solution I received " lever up the two flushing buttons with a fine blade screwdriver.
They may be a push fit on two plastic posts. Once off, they reveal a screw between them. Release this to remove the cistern lid. Make a note of the position of the buttons as they only fit one way round."
11/5/2011 2:06:47 AM • Caroma 270W-RF ... • Answered on Nov 05, 2011
How do I control the tank water level? It
you can go to any home improvment store get a fluidmaster fill valve about $8.00 and very simple to install.Comes with instructions to install and how to set water level cut off!!
6/12/2011 12:44:40 AM • Caroma 270W-RF ... • Answered on Jun 12, 2011
I have a 1998 Caroma Reflections cistern p/n
the inlet washer needs to be replaced to stop the overflow, the washers are easy to get and cheap but trying to get the unit open to replace the washer is my big question at the moment
9/29/2010 4:56:32 AM • Caroma 270W-RF ... • Answered on Sep 29, 2010
Water runs after it fills up?
I am not familiar with that model, but it sounds like your fill valve is leaking or the water level in the tank is too high. Take the toilet tank top off and flush the toilet. When the water gets full and you hear the water stop ( except for your leak) look at the flush valve. Is water running over the top of it and running into the hole in the middle? Then the float need adjustment.
If you are hearing you leak still, lift up on the float. Did it stop? if so the valve may need adjustment due to it not seating completely. You can probably find something online (youtube) easier than I can explain it.
9/8/2010 4:17:48 AM • Caroma 270W-RF ... • Answered on Sep 08, 2010
I have an old Caroma Dual flush ( 15-20 years) and
Well luckly the velve can be replaced by a modern 1. iets not exspensive and dosent take long to do, u will get a step by step apon perches.
Plz rate my advice
7/12/2010 6:06:02 PM • Caroma 270W-RF ... • Answered on Jul 12, 2010
When filling the tank, water squirts out from the
This is Not and i know its rediekules a mistake lol
Sum velves makes dos do hat, the most simpel solusion if u cant live with it is to get a new velve or to try and get a lower cap that gous over that part, bt jip as a plumber myself i also vind it weard they make it that way
Plz rate my advice thanx
7/12/2010 5:52:20 PM • Caroma 270W-RF ... • Answered on Jul 12, 2010
How to replace Caroma toitet suite outlet valve
Hello
Rossouw R. im a plumber.
Were the flexi hose go in to the toilet and conect up to velve thread tape. unscrew the flexi hose and then the plastick nut holding the velve on to the sistern.
put the new velve in and bobs ur uncel.
Its very easy, just look were the 2 seal rubbers are when u remove it, may be 1 rubber.
and the flout of the velve will be a cup or ball, thast ajast that tothe right water level, u will c were the flout or ball is on new velve there will be plastick with bumps un it [most commen] if not let me know bt around that area u should find somting to adjust the hight. sorry for spelling errors, im a plumber nt a english major lol
plz let me know if u get in a rut and plz rate my advice, thanx
7/11/2010 7:17:38 PM • Caroma 270W-RF ... • Answered on Jul 11, 2010
Water is leaking out , close water off then water
Your flush valve (flapper) is leaking. Some of these rubber flappers snap on to posts. Others, slide down the overflow tube. Others are the plunger type that lift straight up and down (some of these have a gasket on the bottom that go bad.) In any case be sure flapper closes properly. Make sure the chain to the handle isn't so long as to get between valve and seat holding flapper open. If all else fails buy a fluidmasgter flush fixer repair kit and follow directions. I had a similar problem one winter and wasted about 200.00 on water.,
7/11/2010 3:36:04 AM • Caroma 270W-RF ... • Answered on Jul 11, 2010
Caroma 270W-RF  Reflection Round Front Dual Flush Toilet - White Logo
38 questions posted
Top Caroma Home Experts
Ngoro
john h
Are you a Caroma Home Expert? Answer questions, earn points and help others
View Most Popular
Caroma Home
  • Caroma Home
Most Popular Question
stop bathroom tap from whistling
  • Home
