20 Most Recent
Toto UltraMax One Piece Toilet, 1.6 GPF - CST854S-11 - Colonial White Questions & Answers
Replace flapper valve in ultramax
Your Toto has the "G-Max" flush valve system. The Korky/Lavelle folks have a carded replacement flapper #2021BP for it. It is red in color and the only generic flapper that will work on your toilet. While it may look the same, do not confuse it with the blue flapper #2022BP. Known as the PowerMax flapper, the blue color is to distinguish between the two and the flappers are totally toilet specific. Let your fingers do the walking and locate a hardware store near you that carries the Korky/Lavelle brand or it can be ordered online from several places using the part number for your search word.
If the fill valve ever stops filling correctly, the Lavelle "Quiet Fill", #528BP, is what Toto uses in most of their toilets.
Toto Neorest 600 issue of low water pressure
page 35 of your instructions. Don't have it, here is a link copy and paste
https://www.totousa.com/filemanager_uploads/product_assets/OwnersManual/0GU9001R_NEOREST_600_EN_OM.pdf
7/8/2023 3:46:16 PM •
Toto Home
Answered
on Jul 08, 2023
Toto washlet s300 has developed slow leak from behind brass connection and plastic.
If you are able to identify the source of the leak, you may be able to fix it yourself. If the leak is coming from the brass connection, you may need to replace the connection or tighten it. If the leak is coming from the plastic, you may need to replace the plastic part or use a sealant to stop the leak. If you are unable to identify the source of the leak, it is best to contact a professional plumber to help you diagnose and repair the issue.
3/16/2023 9:59:53 PM •
Toto Home
Answered
on Mar 16, 2023
The stream on "Rear" is weak on my new Toto Washlet GL since I got it 1 week ago. The "Soft Rear" setting works OK, but the normal Rear wash is no stronger than the "Soft" setting.
It sounds like you may have a problem with the water pressure for the rear wash setting on your Toto Washlet. Here are a few things you can try to troubleshoot the issue:
- Make sure that the water supply hoses for your washlet are securely attached and not kinked or clogged.
- Check the water pressure at the source (e.g., the wall outlet or the valve under the sink). If the water pressure is low, that could be the cause of the weak stream.
- If the water pressure is fine, try cleaning the nozzle for the rear wash setting. Sometimes debris can accumulate in the nozzle and cause the stream to be weak.
- If none of these troubleshooting steps help, you may need to contact Toto customer service for further assistance. They should be able to provide you with additional guidance or arrange for a service technician to come and check your washlet.
1/6/2023 8:31:31 PM •
Toto Home
Answered
on Jan 06, 2023
