20 Most Recent
Villeroy & Boch 5C06 01 P8 Twist One Piece Elongated High Performance Sipho Questions & Answers
Villeroy & Boch flush
Hi pervana....
You have an obstruction in your ballcock/inlet valve or the ballcock/inlet valve is malfunctioning and is need of replacement.
Try to move the float up and down inside of the bowl, this may loosen the valve and allow water to enter the tank.
If this does not solve your problem then you will need to replace the ballcock/inlet valve.
Free Answer...Please take time to rate me
Our V&B Toilet is leaking water from the base
yes it is a wax seal under the toilet, There is just 2 screws holding it down to the floor. Anybody could take it up and fix it.
The bolts are on the two sides down on the base. Prob has small square covers over them
Leaking water into bowl
Your question has been posted under the heading of Villeroy & Boch. If this is the brand you are working on then the flush valve is set up like the old Mansfield Fush valves and is replaced in the same way. But if VB is the brand you might try calling 877-505-5350 it is or was their US number. Hope this helps.
Water leakage inside flush tank
you will need to find out the brand name of your flush/fill valve. some valves merely twist to achieve a new fill level. others work differently. UNLESS, it is the kind with the float ball at the end of a rod. In that case, just bend the rod slightly down if the tank is overflowing.
Villeroy & botch whirlpool does not work
Can you describe the issue at hand a little more?
- What were you doing when it quit?
- How does it normally turn on/off?
- What do the controls look like to turn the tub on?
Rod
US Parts Center
888-521-6183
