20 Most Recent
Grohe 3427 Concetto Single Hole Bathroom Faucet - Chrome Questions & Answers
Bathtub faucet leaking a lot
Change the gaskets.
www.fixya.com/support/p1162411-
grohe_
3427_
concetto.../popular
Popular Grohe 3427 Concetto Single Hole Bathroom Faucet - Chrome questions, problems & fixes. Find expert solutions to common issues, DIY guides, repair ...
Grohe 3427 Concetto Single Hole Bathroom Faucet ... - Fixya
www.fixya.com/search/...
grohe_
3427_
concetto.../
grohe_faucet_leaks
Grohe 3427 Concetto Single Hole Bathroom Faucet - Chrome, grohe faucet leaks related issues. Get free help, solutions & advice from top Grohe experts
Shower hot and cold
It sounds like your talking about the valves under the the lav faucet like from the pic that is showen in your post. But you used the word "SHOWER HOT AND COLD" So I am going with the idea that you are talking about a shower valve.
If your talking about the screw driver stops to each side if it is leaking from the around the center of the screw stop. You may just need to tighten the nut on the outside that the stem goes though.Or you can take the nut off (tirn off the water to the building) and get some rope packing and run a couple of rapps around the stem replace the nut and tighen and turn the water back on.
If it still leaks some to the samething over again just put more packing in. Should cost you about 5 dollars
Best of luck Tom
We have a Grohe faucet similar to the Concetto.
looks like you'll have to remove it and examine it. Brass is a soft metal, I hope you've not stripped out the threads, Grohe is an expensive faucet. i fall else fails and the hreads are stripped out, I might try a tough adhesive caulk like a 3M 5200 marine grade. Apply liberally from the bottom. let it set firmly. Perhaps tape a piece of cardboard over the hole in the countertop from the bottom. this would keep the caulking from falling out before it sets. unconventional, but something to try before buying another $200 faucet. what have you to loose?
Grohe LadyLux kitchen pullout sprayer hose has spring surrounding the hose under the sink and is not retracting properly
there may be an issue with the hose or the weight that is attached to the hose under the sink. Here are some steps you can follow to troubleshoot the issue:
- Check the weight: There should be a weight attached to the hose under the sink. This weight is designed to help the hose retract back into the faucet. If the weight is loose or not in the correct position, it can affect the retracting ability of the hose. Make sure the weight is securely attached to the hose and is in the correct position.
- Check the hose for obstructions: The hose may not be retracting properly due to an obstruction. Turn off the water supply to the faucet and disconnect the hose from the faucet. Carefully inspect the hose for any kinks or blockages. If you find any obstructions, gently straighten out the hose and remove the blockage.
- Check for damage to the hose: The hose may not be retracting properly due to damage. Check the hose for any visible signs of wear and tear, such as cracks or tears. If the hose is damaged, it will need to be replaced.
- Lubricate the hose: Over time, the hose can become dry and lose its flexibility. Apply a small amount of silicone lubricant to the hose to help it move more freely.
My grohe drain stopper is not holding in closed position. Is there a solution.
If it is a press and lock style, some of them can be pulled out and adjusted to make for more clearance so the locking mechanism has room to work. If it's the style that uses a pull rod from behind the spout, then the circular nut that holds the pop-up rod into the drain directly under the sink. If that's loose, then it won't allow the pop up to stay in place. Hope this helps
How do I fix slow drain brand new plumbing?
The drain pipe may not have been installed correctly - the slope may be wrong, or the pipe may be too small, or you may have too much backpressure, or if you have a septic tank it may be full and need pumping, or any number of other possible problems. You might have another plumber come for an assessment and opinion - make it clear that you don't necessarily intend to hire them to do any WORK, you just want their opinion. Then they won't try to sell you all new plumbing to replace what you just bought...
I have a single handle Grohe bathroom faucet and I cannot get the handle to uncouple from the faucet to replace the cartridge. I have removed the set screw.
Any ideas?
Corrosion/hard water scale has built up between the slotted shaft and the handle .... "cementing" it in place.
A faucet handle puller may help depending on your design. This video shows how for a 2 faucet sink setup...but your 1 faucet handle should be similar. The puller will ONLY work though if you can access the end of the slotted shaft to get leverage from. Can you remove an end cap from the handle to access the shaft? ...
If the puller will not work ....
You could try penetrating oil (if you can get the oil to the corrosion) ... or if your handle is metal, cover it with a wash cloth to prevent marring and tap with a brad hammer. Sometimes that breaks the corrosion bond.
You could also try heat/cold/heat/cold by heating with a hair dryer followed by a bag of ice water and then repeat. The temperature cycling might help.
In a real pinch ... but you have to VERY careful ... use a pry bar between the escutcheon plate and the handle...go slow .... use cloth protection to prevent marring ... move the pry bar around and rock it....say at 12, 3, 6, 9 o'clock positions around the handle
AND .... when you are successful ... when you reinstall ... put some silicon plumbing grease on the shaft to prevent future corrosion!
