20 Most Recent Delta Faucet Delta 467-SSSD-DST Palo Diamond Seal Kitchen Pull-Out or Out Faucet Brillia Questions & Answers
Delta Faucet Company 467-SSSD-DST Palo
It sounds like the cartridge is going or is possibly loose, If you take the handle off you can try to GENTLY tighten the cartridge and see if that fixes the leak. You don't have to tighten it a lot to see if it will stop; if you over tighten you can cause the housing to split and you don't want to strip the cartridge head because you may have to remove it. Use a proper set of channel locks and apply some gentle pressure if it turns and the leak stops, great! if it doesn't then the cartridge has failed and needs replacing. Your Delta faucet is covered by a limited lifetime warranty so the part should be free. Here is the warranty and the contact information to order one. https://www.faucetdirect.com/index.cfm?page=product:warrantyPopup&uniqueId=2417692 If you are not comfortable dealing with plumbing issues I would highly recommend calling a licenced plumber. The part is free so its simply the plumbers time. Good luck.
10/18/2017 2:41:20 PM • Delta Faucet... • Answered on Oct 18, 2017
Delta faucet #467-DST. The
There are two rubber o rings under the spout, one at the top and one on the bottom, Remove the handle then the nut that you will see that is in contact with the spout. Rock the spout left to right and pull up at the same time. You then can replace the O rings and make sure you put some food grade lub on the O rings. Replace all that you took off and you are god to go.
best of luck Rich
9/7/2011 8:13:41 PM • Delta Faucet... • Answered on Sep 07, 2011
Delta 467sssd hard to turn
there may be under the handle is a crown nut + a plastic collar which holds down the inards there is a tool that works this. it can be gotten at hardware store.. handle usely comes off w/ 1/8 allen wrench...
3/31/2011 3:52:58 PM • Delta Faucet... • Answered on Mar 31, 2011
I have a Delta kitchen
Take the handle off (set screw underneath)
Then turn the top off under the handle....make sure water is off...
then you will find a ball with the handle stem on it....note the position of it and pull it out...
under there are two wets of springs and rubber seats...
pull the right side out and check the hole for a blockage...(dirt or rust)
if none is visible, you may have to unhook the cold water supply hose
and then blow compressed air back through the hole to remove the blockage...
then reassemble...
heatman101
3/20/2011 5:49:30 PM • Delta Faucet... • Answered on Mar 20, 2011
I have a Delta kitchen faucet Palo 467 series. I
Are you using a softener in your home? Sometimes hard water deposits can clog up the cartridges and create the problems you such described. Im not sure about the lock/button issue though since I have never used this particular Delta faucet myself, but with one problem, it can usually cause many others.
Try replacing the cartridge on the Delta faucet first, Here is a link to the replacement one from the Delta site. http://www.deltafaucet.com/repairparts/details/RP50587.html
Here is a link to Delta warranty and lifetime guarantee. http://www.deltafaucet.com/customersupport/warranty.html
Here is a link to the Delta page with lots of useful information on your product. http://www.deltafaucet.com/kitchen/details/467-DST.html
Ex-Plumber
Hope this helps-
J.Sper
3/6/2011 4:18:54 PM • Delta Faucet... • Answered on Mar 06, 2011
Delta Faucet Company 467-SSSD-DST Palo Diamond
I hope this will help please go to this web site for a downloadable parts link. If it is leaking from the spout replace the seats and springs to correct the problem. Turn water off and remove handle with a 1/8" allen wrench and remove retaining collar to access the ball assembly to remove the seats and springs.
The parts page on this link will give you a break down and hope this will help.
http://www.deltafaucet.com/kitchen/details/467-SSSD-DST.html
12/30/2010 2:42:55 AM • Delta Faucet... • Answered on Dec 30, 2010
Our hot and cold water seem to be mixing. we had
When you filled the water heater did you get all the air out of lines and water flowing before you turned power onto heater. It sound's like the bottom element on the heater is not working. That is if it's the same throughout the house hot then get's cold.
Check the power to the lower element and thermostat.
7/13/2010 9:08:48 AM • Delta Faucet... • Answered on Jul 13, 2010
How to remove stuck cap for delta single handle faucet
Take a rag and put over nut then tap all-around nut. Then use your hand to try and unscrew. A strap wrench is the best tool for taking these off. I have been to so many of these where the homeowners have used channel locks or pipe wrenches and scarred up nut or broken off copper tubes. They seem amazed when i tap it a few times and remove it with my hands. Channel locks and pipe wrenches actually cause the nut to bind when using this much force. Make sure you loosen the plastic retainer on top of the nut first.For more details about single faucet repair
8/24/2021 4:21:14 AM • Delta Faucet... • Answered on Aug 24, 2021
The single handle Delta kitchen
remove the handle that turns water on and off , usually an allen wrench lift and swing back and forth at the same time. the spigot should come off. replace o rings lubricate with silicone grease reinstall spigot and handle
11/16/2017 4:52:11 PM • Delta Faucet... • Answered on Nov 16, 2017
2answers
Low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
1/26/2016 4:43:03 PM • Delta Faucet... • Answered on Jan 26, 2016
2answers
Delta 400-DST Single Handle Kitchen Faucet Spigot Drips
I've installed quite a few of these from the big box stores that leak. There are 2 rubber pieces inside the valve body that act as seats. The seats are what turn the water on and off as you move the handle. These rubbers need to be replaced. You can buy a delta repair kit, which will contain these parts. Where the faucet is new, it might be easier to bring it back
6/16/2014 5:01:02 PM • Delta Faucet... • Answered on Jun 16, 2014
Water will not flow through the bathroom faucet
It probably is a clogged aerator. The small piece, right where the water comes out, unscrews. There is a screen behind it the often collects dirt and minerals. Clean that off and try it again
4/29/2014 1:03:55 AM • Delta Faucet... • Answered on Apr 29, 2014
Wanter not going throught the bathroom faucet
Unscrew and clean aerator.
1/18/2014 1:31:56 AM • Delta Faucet... • Answered on Jan 18, 2014
What causes black **** to build up in the water faucets and the dishwasher and everywhere water comes into the house? We have had the water company here soooooo many times and now they are saying they
The cause is Hydrogen Sulfide either in the wells they are pumping from or due to bacteria. Do you also have a 'rotten egg' odor? High concentrations of this gas can be deadly. You should get the yearly report the water company must produce on the composition of your water and analyze it. You may want to have the water in your home testes to see if it has the same percentage of H2S that they are reporting. You can remove some of it by Carbon Filtration but you would have to speak to a local water treatment company.
11/15/2013 1:11:12 AM • Delta Faucet... • Answered on Nov 15, 2013
When I first turn on the hot water to my shower there is a loud noise, then it goes away. Why is this happening?
It could be lime/ calcium deposits in the shower head. Soak shower head in clr and it should be good to go
2/28/2013 5:50:41 AM • Delta Faucet... • Answered on Feb 28, 2013
Base of single handle kitchen faucet is loose where it sits on the counter
there should be 2 plastic nuts under the sink that hold the fixture tight to the sink. if they are tight allready try to install washers and see if that helps. right is tight. left is loose.
6/8/2012 12:18:12 PM • Delta Faucet... • Answered on Jun 08, 2012
Low pressure and have take head apart not plugged
Modern low flow plumbing devices reduce water flow by using smaller passages inside the unit. The downside of this conservation is that appliances are more easily clogged by debris that may be in the supply lines. Frequently it gets stuck in the cartridge. I have even found it in the supply line connections.
12/31/2011 10:32:17 PM • Delta Faucet... • Answered on Dec 31, 2011
Our RSVP faucet, 6590-PC is leaking. We do not
Just faucets in general I look underneath..they are often attached W/ nuts ..
4/7/2011 4:39:08 PM • Delta Faucet... • Answered on Apr 07, 2011
Delta Faucet Delta 467-SSSD-DST Palo Diamond Seal Kitchen Pull-Out or Out Faucet Brillia Logo
Popular Tags
21 questions posted
Top Delta Faucet Plumbing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
View Most Popular
  • Delta Faucet Plumbing
Most Popular Question
delta kitchen faucet palo 467 series
  • Plumbing
