Same problem. Only after 2 months of buying silk epil 7 epilator, it stopped charging and is not working at all. There is very few customer service centres of Braun in India. So it is very difficult to contact them and show your product to find out the issue.
You will need a star-shaped bit to remove the 2 screws. I would imagine they’re metric as it’s made in Germany. Barring that, a small flat head screwdriver used for eyeglasses will work. Remove the screws over a bucket or something so you don’t lose them, because they’re specific to the SilkEpil and can’t be bought at the hardware store.
When you remove the screws and take it apart, you’ll see the gears inside are clogged with hair. The flaw with the design is that the gear mechanism will suck in a few hairs every time you use it, which build up over time.
Remove the gear unit and use tweezers to pull out all the hair. You can rotate the gears to get it all. On the underside of the tweezer section, there’s a little recessed gear that’s probably clogged with hair too. Rotate the tweezer barrel to turn the little gear, and pull out the hair.
Give everything a good rinse, put it back together, and let it dry overnight. Presto, good as new!
I plan on doing this once a year as regular maintenance.
All the details Anna, starting with the conclusion.
CONCLUSION. To conclude, diode lasers are better for hair reduction and pigmentation removal, while IPL lasers can be more versatile and can address a wider range of skin concerns. The choice between the two will depend on the specific needs and goals of the patient.
Jan 31, 2023
Braun Series 3 Electric Razor disassembly and battery replacement (original and AA NIMH batteries) (youtube.com)
Braun 9-in-1 Trimmer - Disassembly/Battery Replacement (youtube.com)
Remove the Screws: First, you'll need to remove any screws that hold the device together. Look for visible screws on the casing or housing. Use the appropriate screwdriver (usually a Phillips or Torx) to carefully unscrew them.
Open the Casing: Once the screws are removed, gently pry open the casing. Be cautious not to damage any delicate components inside. You can use a flathead screwdriver or a plastic opening tool for this step.
Access the Battery: Inside the casing, you'll find the battery. Depending on the specific Braun device, the battery may be soldered in place or connected via a connector. If it's soldered, you'll need to desolder the connections. If it's connected via a connector, carefully disconnect it.
Replace the Battery: If you have a replacement battery, insert it in place of the old one. Make sure to observe the correct polarity (positive and negative terminals). Secure the battery back in its position.
Reassemble the Device: Put the casing back together, aligning all the components properly. Screw it back in place.
Test the Device: Once reassembled, check if the device powers on. If it does, congratulations! You've successfully replaced the battery.
