20 Most Recent
Braun Impression KF 600 Coffee Maker Questions & Answers
I have a Braun KF600
Sounds like it could be a bad heating element, you could try to find a replacement but it would be pretty pie in the sky.
This is the cheapest replacement that I could find.
http://compare.ebay.com/like/140541415123?var=lv<yp=AllFixedPriceItemTypes&var=sbar&rvr_id=229795861013&crlp=1_263602_309572&UA=L*F%3F&GUID=bca9cdf912f0a0aa17765ae6ffe0749e&itemid=140541415123&ff4=263602_309572
The coffee maker shuts itself off prematurely even
For your safety and convenience, the Braun coffeemaker features an auto-off function. It automatically switches your coffeemaker off as soon as your coffee is brewed. So you don't need worry about switching it off .
but if in your model there is no auto -off function set and still the coffee maker shuts off.then its the problem of heating plate or the power supply problem.if the plate or power supply board is faulty both gets overheated and to save the unit from major damage the coffee maker automatically shuts off in between.
so check out both the heating plate as well as the power supply board and confirm the fault and replace that part.
This will help. Thanks please keep updated.please do rate the
solution positively .thank you for using fixya
Braun KF 600
I am thinking about purchasing this model; so I am very interested in your report.
We are replacing a Braun KF 145 that's about 8 yrs old.
We had a similar problem that was solved by taking care with the coffee filter basket. Always close the basket firmly in place before you place the carafe in position. The overflow problem only occurred when we placed the carafe first and then closed the filter basket.
Maybe the same mechanics apply with the KF600.
Reed
