20 Most Recent Delta X5 3Hp Left Titl Unisaw with Unifence Questions & Answers
Delta 10 inch unisaw switch hums wont start motor
All of the above are correct. However, before you go nuts with motor stuff, unplug the saw and make sure the blade shaft turns freely, If it doesn't, look for something jammed in the belt and pulley mechanisms. Loosen the drive belt and check the motor shaft rotation and the blade shaft rotation separately. If you find nothing, remove the belt and try starting the motor. If it won't start like this (no load) there is a motor problem. If it does start, find the drive mechanism problem and fix it; not many possibilities. Good luck. I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_f6ca18ca1db028ed
12/3/2017 1:57:06 AM • Delta X5 3Hp... • Answered on Dec 03, 2017
2answers
I have a five year old Unisaw and the 45 degree
so, what's the problem?
12/3/2017 1:46:00 AM • Delta X5 3Hp... • Answered on Dec 03, 2017
Delta Unisaw 34-782 Starts with a "Bang"
The capacitor is probably failing. Take the motor to an electrical service center (most mid-to-large cities have them ... usually something like "Industrial Electric and Motor Service" ... and ask to have it checked. Caps are cheap!
11/3/2017 12:54:53 AM • Delta X5 3Hp... • Answered on Nov 03, 2017
Motor won't stay running
This maybe the Run capacitor. If not handy, remove and bring to a motor shop as some capictors are internal!
12/8/2014 5:27:56 PM • Delta X5 3Hp... • Answered on Dec 08, 2014
Bladewillnot lower
sometimes when the blade is lowered too far the gears can get stuck. First try a reasonable tap with a mallet. If that fails you will need to access the mechanism, grease it and get it operating again
8/18/2014 8:13:22 PM • Delta X5 3Hp... • Answered on Aug 18, 2014
Delta x5 unisaw 3 hp.
The motor has a component called a clixon (there are other names for it, too). The clixon has a step up coil and a capacitor that gives the motor an extra bit of juice to get started turning. When it fails, you get the kind of thing you're talking about. If you keep trying to use it without this component working, it overheats the windings and shorts the motor out, killing it. You're most likely going to end up replacing the motor now.
Sorry I didn't have better news for you.
7/9/2011 6:35:10 AM • Delta X5 3Hp... • Answered on Jul 09, 2011
My blade is running backwards how do i fix it
Take the blade off and turn it around.
Take the cover off the side of the motor (unplugged of course) short any capacitor with a screwdriver to the metal side of the motor.  The wires should be able to be accessed and switched through an end-plate on the motor. The wires should be on connectors and can be pulled out easily with a pair of needle-nose pliers.
Be sure that device is unplugged prior to servicing.
Good Luck.
6/13/2010 11:03:31 AM • Delta X5 3Hp... • Answered on Jun 13, 2010
When I returned from a
You only have 2 spots that will stop the blade from coming down unless something broke. There is a pin in the trunnion gear thing that is the stop. With the blade off, you can see the pin, right above the gear cut, it stops on a big pin in the back of the gear. It could be covered with stringy stuff and you wouldn't see it. And the other spot would be the back of the motor when it drops down, it could be hitting on a block of wood at the back of the saw. I can't see anyplace else it would stop. Did somebody use the saw while you were gone? Did they change the blade? How about the belt? I'm dieing to find out what happened. Hope this helps.
5/18/2010 1:42:03 AM • Delta X5 3Hp... • Answered on May 18, 2010
I recently (8 days ago) changed the starter on my
What is the rating of the starter overloads. A more basic question, are they adjustable or the heater type? It sounds like the starter overloads are taking you out. Check the full load amps of the motor you are using against the overload rating. Add 10% to this and set overloads at ths setpoint if adjustable. If heater equipped buy new heaters rated for motor load. Make sure to use the 1 phase rating and not the 3 phase. That is if you are using a 3 phase starter.
4/4/2010 12:10:04 PM • Delta X5 3Hp... • Answered on Apr 04, 2010
I have a 1979 unisaw and it is burning stock
I would use a straight edge, to see if the blade is parallel to the table. Bring the blade up, put the straightedge on it and measure to one of the dado cuts in the table, front and back should be the same. If not, You can loosen up the mounting bolts underneath and tap the whole thing around to square it up. Hope this helps.
3/3/2010 8:39:18 PM • Delta X5 3Hp... • Answered on Mar 03, 2010
Blade will not go to 90 degrees vertical to saw
This is an easy adjustment to make. Begin by unplugging the saw for safety. Here is a copy of the owner manual which explains exactly what to do on page 35 with pix.
http://www.leestyron.com/pdf/delman.pdf
4/25/2009 2:41:45 AM • Delta X5 3Hp... • Answered on Apr 25, 2009
Motor is having trouble getting started. Once going it works OK
Does it have a run capacitor? Maybe that's the culprit.
Does it have a centrifugal switch for disconnecting the start winding and engaging the run winding? If so, could the centrifugal switch be stuck.
4/22/2009 12:46:26 AM • Delta X5 3Hp... • Answered on Apr 22, 2009
Lost Owner's Manual
click this link to download your owners manual -->click here<--
Please take the time to give this solution a "Fix Ya" rating.
Thanks for using Fix Ya
1/31/2009 6:36:21 PM • Delta X5 3Hp... • Answered on Jan 31, 2009
Is there any brand to replace Delta splitter table saw part 1313277
This video says another Delta fits 8,198 views May 19, 2019 After getting my contractor table saw (base model 36-451) out of storage, I noticed my splitter and guard was missing (go figure). I really wanted the kickback protection while cutting narrow parts, so after long time searching, I found the Delta 34-868 drop-down splitter. It did say it would fit my saw, but the screws were the wrong size. Watch the video to see how I overcame it and how it performs. I love it... And this is it
DELTA 34-868 Bracket and Splitter Assembly
Amazon.ca https://www.amazon.ca > DELTA-34-868-Bracket-Spl... With anti-kickback fingers it provides protection for all sawing operations, disappears below table for dadoing and other non-thru cutting jobs ... Rating: 4 · ‎84 reviews · ‎$127.55 · ‎In stock
10/6/2023 4:23:04 PM • Delta Saws • Answered on Oct 06, 2023
2answers
Delta 36-510 blade turning slow. Motor running fine, but blade barely turning
is blade tight, are the blade washers in place, willl it cut a pice of wood? if it does not cut wood look at part 321 Delta 36 510 Parts List and Diagram Type 2 eReplacementParts com NOS Delta Table Saw Jackshaft Assembly 1343258 for 36 510 T2 Bench Saw eBay
12/2/2022 2:17:34 PM • Delta Saws • Answered on Dec 02, 2022
Delta X5 3Hp Left Titl Unisaw with Unifence Logo
Popular Tags
18 questions posted
Top Delta Saws Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
Kardoc
Are you a Delta Saw Expert? Answer questions, earn points and help others
View Most Popular
Delta Saws
  • Delta Saws
Most Popular Question
motor having trouble getting started
  • Saws
