20 Most Recent Eclipse 180g2 4gb Mp3 Music/vid - 180 G2 Rd - Questions & Answers
DOWNLOAD MUSIC
MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet to your computer and then copy them to your MP3 player using the USB cable. For your CD collection, you need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player after you have connected the USB cable to the MP3 player and the computer. You can do this using Windows Media player and Rip the CDs - Media Player will create a MP3 music file for each music track. Click on this link for instruction on converting music files to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
9/23/2022 2:14:18 AM • Eclipse 180g2... • Answered on Sep 23, 2022
3answers
How do i put music on my Eclipse mp3
go to mp3juices.cc and download then go to computer open 2 windows then go to downloads one of the boxes click the mp3 driver and drag over into the file desired by opening and dropping.
3/22/2023 8:07:17 AM • Eclipse Audio... • Answered on Mar 22, 2023
What is err_no=0x50000011 - Eclipse Audio Players & Recorders
"err_no=0x50000011" is an error code that may appear on an Eclipse audio player or recorder. This error code typically indicates a problem with the firmware or software on the device. The specific cause of the error and the steps needed to resolve it may vary depending on the model and specific circumstances of the device. Here are a few things you can try:
  1. Restart the device: Sometimes, a simple restart can resolve software issues.
  2. Update the firmware: Make sure that the device has the latest firmware version.
  3. Check the SD card: If the device uses an SD card, make sure that it is properly inserted and that the card is not damaged.
  4. check the battery: Make sure that the device has enough battery or that it is plugged in.
  5. Reset the device: If none of the above steps work, try performing a factory reset on the device.
  6. Consult the manual: Consult the manual for specific troubleshoot and service information for your Eclipse model.
1/14/2023 1:34:30 AM • Eclipse Audio... • Answered on Jan 14, 2023
Hello my eclipse mp3 player will charge but when i take it off the charger it plays for 3 minutes and truns off and i just bought it new what can i do to fix it
It sounds like you are experiencing an issue with your new Eclipse MP3 player. Here are a few things you can try to troubleshoot the problem:
  1. Make sure that the battery is fully charged. If the battery is not fully charged, the MP3 player may not have enough power to stay on for an extended period of time.
  2. Check the charging cable and make sure that it is securely plugged into the MP3 player and the charger.
  3. Check the charging port on the MP3 player for any damage or debris that may be preventing a secure connection.
  4. Try a different charging cable or charger to see if the issue is with the charging equipment.
  5. If the issue persists, you may need to contact the manufacturer for further assistance.
I hope this helps! If you have any additional questions or need further assistance, don't hesitate to ask.
1/1/2023 11:18:23 PM • Eclipse Audio... • Answered on Jan 01, 2023
2answers
How do I format my player to take music from a cd
You can't copy music directly from a CD to an mp3 player. you should rip CD to a computer, geenrating mp3 files and then copy or move those files from computer folder to Eclipse music folder
12/1/2022 5:29:52 AM • Eclipse Audio... • Answered on Dec 01, 2022
3answers
Download songs to my mp3
I always download songs use a youtube downloader from youtube.It can not only download videos from youtube but also convert the videos to the right forma tyou want while it is downloading.You can take a try for this free youtube downloader.
2/16/2022 1:55:42 AM • Eclipse Audio... • Answered on Feb 16, 2022
Fit Clip MP3 player. Where can I get the owners manual?
Contact Eclipse directly to request it.
11/17/2020 2:59:47 PM • Eclipse Audio... • Answered on Nov 17, 2020
How do I get to a PDF of the Eclipse CLD 4GB mp2 player?
Contact Eclipse to inquire.
11/17/2020 2:46:47 PM • Eclipse Audio... • Answered on Nov 17, 2020
My Eclipse mp3 player isn't charging, but I've had it plugged in and it says it's charging. What is happening?
1. Defective battery 2. Defective charger
11/17/2020 2:45:38 PM • Eclipse Audio... • Answered on Nov 17, 2020
Can you download audio books to an eclipse fit clip mp3 player? When I try to download through overdrive I get this error message: Exception from HRESULt: 0x80270800
Not sure. I thought overdrive was an additional gear ratio for a car. The Mp3 player is generally a passive device except when playing a file, that means it has to be loaded with files by an active device. Usually the required files are downloaded onto an active device and then the files can be sent, usually via usb, from the device to the Mp3 player. The audio source, whether disc, vinyl or internet is a passive device and can't be loaded or downloaded or processed into usable files without commands from a active device. So far I have found a desktop computer or laptop to be the ideal active device...
6/13/2020 4:10:30 AM • Eclipse Audio... • Answered on Jun 13, 2020
My eclipse 2.8 mp3 player won't charge
Hi Lezlee Johnson, as you comment, it is very possible that the battery of your Eclipse, is not making good contact or has already fulfilled its useful life Review and comment Regards Franco Dosil Hola Lezlee Johnson, por lo que comentas, es muy posible que la bateria de tu Eclipse, no esta haciendo buen contacto o ya haya cumplido su vida util Revisa y comenta Saludos Franco Dosil
10/14/2019 7:28:08 PM • Eclipse Audio... • Answered on Oct 14, 2019
When i play videos on my eclipse fit clip plus it says format error i dont know what issue it is pls help
There are many different video formats and some players will only play certain formats. Check which formats the player will play. Then look at the formats that it wont play. If the player won't play those that it's supposed to, then you will have a problem. If it does play them and not others, then you need to remove those files it won't and get then converted to ones that can play on your player. There is free software available to convert files on a computer. But some might want to charge you for converting common file types.
10/12/2019 10:14:51 PM • Eclipse Audio... • Answered on Oct 12, 2019
Eclipse MP3 player won't show the songs in the correct order as downloaded
Hi Rarity, check if in your Eclipse MP3, you have not selected the "RANDOM" playback mode If enabled, the order of the topics will be done in a disorderly manner I sent you the link to download the user manual I hope you find it useful Greetings Franco Dosil Hola Rarity, fijate si en tu Eclipse MP3, no tienes selecionado el modo de reproduccion "RANDOM" Si esta habilitado, el orden de los temas se hara en forma desordenada Te envio el link para que descargues el manual de usuario Espero que te resulte util Saludos Franco Dosil https://data2.manualslib.com/pdf5/105/10489/1048840-eclipse/fit_clip.pdf?6550a4082ef5d8940fd0e6cd212445d9&take=binary
5/30/2019 6:24:18 AM • Eclipse Audio... • Answered on May 30, 2019
I just bought 4 new fit clips Eclipse 4GB MP3 players and none of them will charge. I have older ones, that will show the movement on the screen when it is charging. Charged them all night.
Return it for one that works. I have no problem returning items that are defective or inoperable for one that works as designed. The are no serviceable parts, items are throw away wen no longer working. I have had players fail after years of service so I replaced them, there are 3 players in my drawer that I use
5/28/2019 1:40:04 PM • Eclipse Audio... • Answered on May 28, 2019
Eclipse 180g2 4gb Mp3 Music/vid - 180 G2 Rd - Logo
2 questions posted
Top Eclipse Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Eclipse Audio Players & Recorders
Most Popular Question
download music
  • Audio Players & Recorders
