20 Most Recent McCulloch 10" Electric Pole / Chain Saw Questions & Answers
Wondering what size file to use to sharpen an MCP1510
McCULLOCH MCP1510 is not a good pole saw. You can't easy to use with this pole saw. If you want to find the best pole saw in 2018 go to the https://thebestpolesaw2018.yolasite.com/
3/21/2018 8:56:30 AM • McCulloch 10"... • Answered on Mar 21, 2018
MS1015P McCulloch pole saw, stripped
I recommend contacting your local authorized service center for assistance. You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links: Contact us User manuals What is the correct fuel mixture for McCulloch products Chainsaw Trimmer... McCulloch Service McCULLOCH PARTS ACCESSORIES I trust this information has proven beneficial. helpful-rx44h4hsqebyqg3voy0wii3n-2-0_5.png
3/10/2018 7:01:11 AM • McCulloch 10"... • Answered on Mar 10, 2018
I need a sprocket and roller bearings for McCulloch MCP 1510 pole saw
Try Amazon, eBay or you may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links: Contact us User manuals What is the correct fuel mixture for McCulloch products Chainsaw Trimmer... McCulloch Service McCULLOCH PARTS ACCESSORIES I trust this information has proven beneficial. helpful-rwwceix4simen0bu2pand4lt-2-0.png
3/1/2018 5:54:50 PM • McCulloch 10"... • Answered on Mar 01, 2018
Mcculloch 10 inch electric chain saw-motor turns but not the chain
You'll need to get that looked at. I recommend contacting your local authorized service center for assistance. You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links: Contact us User manuals What is the correct fuel mixture for McCulloch products Chainsaw Trimmer... McCulloch Service McCULLOCH PARTS ACCESSORIES I trust this information has proven beneficial. helpful-rwwceix4simen0bu2pand4lt-2-0.png
2/21/2018 4:42:56 AM • McCulloch 10"... • Answered on Feb 21, 2018
How do you replace the fule lines that goes inside the gas tank on a poulan 445 pro
A replacement kit typically includes instructions. Otherwise check your service manual or search Youtube. You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links: Contact us User manuals What is the correct fuel mixture for McCulloch products Chainsaw Trimmer... McCulloch Service McCULLOCH PARTS ACCESSORIES I trust this information has proven beneficial. helpful-rwwceix4simen0bu2pand4lt-2-0.png
2/20/2018 4:09:46 AM • McCulloch 10"... • Answered on Feb 20, 2018
Need to no how to hook gas lines bock up install new lines and primer bulb not sure got lines hooked up right
Always, always, always take pictures before taking anything apart. I recommend contacting your local authorized service center for assistance. You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links: Contact us User manuals What is the correct fuel mixture for McCulloch products Chainsaw Trimmer... McCulloch Service McCULLOCH PARTS ACCESSORIES I trust this information has proven beneficial. helpful-rwwceix4simen0bu2pand4lt-2-0.png
2/20/2018 4:06:16 AM • McCulloch 10"... • Answered on Feb 20, 2018
Need number for poulan pole saw trimmer for primer button
There is NO primer, your using an electric pole saw !
7/3/2016 1:05:56 PM • McCulloch 10"... • Answered on Jul 03, 2016
Need routing gas line
You can't........your using an electric chain saw !
7/3/2016 1:02:44 PM • McCulloch 10"... • Answered on Jul 03, 2016
It does not start
There are three essential things to have with a small engine. 1/ Fuel 2/Spark 3/Timing Pull your spark plug and see if it is wet. Check to insure you have new fuel. Your problem may be in the diaphragm or plugged vents. Unplug vents and replace diaphragm if needed. . When the plug is pulled ground the plug to the outside of the piston. Pull your cord and see if you have spark. Replace plug with a new one. Timing may be off. Check your flywheel key to insure it is not sheared. If both are present and after you have determined that you did not flood it. Try again to start without pulling the choke. If it does not start then try by pulling with the choke on. It may also be that you have no compression. If it feels really easy to spin it might mean that your rings on the piston have collapsed. Time now to take it to a pro if this is the problem. Cost of this repair be prepared to buy a new one.
11/28/2015 9:28:01 PM • McCulloch 10"... • Answered on Nov 28, 2015
MAC 7-38 chainsaw stalls when you open the throttle. Any ideas?
We are talking about an electric chain saw ?
I would say you are not getting oil to the bar chain sprocket. Do you have enough bar oil in it ?
3/17/2015 1:58:58 PM • McCulloch 10"... • Answered on Mar 17, 2015
Loose chain
you have to loosen the bar then there should be a screw behind the bar or a slot in the bar to put a screw driver. turn till tight then you hold it there and tighten the bar back up
9/30/2013 4:43:12 AM • McCulloch 10"... • Answered on Sep 30, 2013
I NEED HELP WITH FUEL
I HAVE A POULAN PRO 445 POLE SAW AND NEED AN FUEL FILTER AND HOSES . IS THERE ANY WAY I CAN SEE PARTS # FOR THESE ITEMS AND ALSO A PIC OF PUTTING IT TOGETHER ? Thanks , Omar
4/9/2013 2:11:58 AM • McCulloch 10"... • Answered on Apr 09, 2013
Where to buy a carburetor for a mac 3214 32cc chainsaw?
just buy a rebuild kit from JACKSSMALLENGINES
12/11/2012 4:43:33 PM • McCulloch 10"... • Answered on Dec 11, 2012
2answers
McCulloch electric pole chain saw manual model
McCulloch Manuals
Illustrated Parts Lists: (IPLs) are fairly simple, on the underside of McCulloch saws is a black and yellow tag; the upper number (“Power Mac 320” 600021H) is the model, below it a serial number (11-18555). These 2 numbers are combined to create an IPL number (“Power Mac 320” IPL number = 11-600021H). The IPL number can be used to find the correct IPL for every McCulloch parts supplier I have found. If the parts supplier only list part numbers the proper IPL is the source for the part number.
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! HTH
Lou
Please stress to phone person it is an electric.
5/7/2012 7:46:01 PM • McCulloch 10"... • Answered on May 07, 2012
4answers
I need info on a Poulan Pro 445 fuel line routing
I'm so confused. This is reported as a Poulan and McCulloch pole saw, which one? Is it a pole saw? That is the only 445 Poulan I can find. It is reported as an electric but has a fuel routing problem.
If it is a Poulan Pro gas pole saw it is here: PP445 Gas Pole Pruner
The fuel system routing is terrible, but it is all there is.
Fuel Routing follows:
Tank to carburetor (hose in tank with filter on free end)
Carburetor to primer (primer draws fuel from the tank through the carb)
Primer to fuel tank (returns any excess fuel to tank when pushed) HTH
Lou
10/10/2011 8:59:24 PM • McCulloch 10"... • Answered on Oct 10, 2011
Change all fuel lines in a McCollough Chain Saw,
It should be as illustrated on the link.
Typical Fuel System (Primer Bulb and fuel lines may not apply)
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
The line with the filter needs to be long enough to reach all parts of the tank as the saw is moved. The return line is not a critical length probably mid tank. Do you have the filtered hose feeding the primer and not the carburetor? That will cause what you describe. HTH
Lou
8/8/2011 8:41:54 PM • McCulloch 10"... • Answered on Aug 08, 2011
How to replace fuel filter
The fuel filter is on the free end of a hose inside the fuel tank. Insert a hooked blunted wire through the filler port and gently withdraw the hose.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
8/6/2010 8:25:02 PM • McCulloch 10"... • Answered on Aug 06, 2010
Chain stops when it touchs log
A gas engined saw has a clutch that can slip if overly oiled internally, but electric saws don't use a clutch. Most however, have a safety disconnect to the drive sprocket that shears or otherwise removes power to the chain while the motor runs. The worst problem can be a broken gear within the gearbox and requires dis-assembly to discover. Many modern saws use plastic gears in place of metal ones and are prone to failure. The fact that the chain turns when not under load would seem to eliminate the gearbox, but don't discount that until proven. Hope this helps!
6/26/2010 7:37:47 PM • McCulloch 10"... • Answered on Jun 26, 2010
Have a Mac 3214, fuel lines were rotten, replaced
The fuel metering needle in the lower carburetor chamber may have a bad rubber tip or the rubber diaphragm may be hard or cracked. McCullough fuel tanks vent through the cap (it should not have a gasket). Gravity plays no part in the carburetor fuel volume. Remove the spark plug (ignition off) and pull the engine through a few times without the choke on, but the throttle wide open to remove excess fuel in the crankcase (no smoking during this procedure). Make sure the plug is dry when you put it back. Hope this helps!
4/19/2010 2:18:47 AM • McCulloch 10"... • Answered on Apr 19, 2010
Need to view gas line hook up. On mac3515 chainsaw
No 3515(35cc,15"bar)s a 3516 is provided.
A McCulloch Mac 3516 model model 21-600035-59. (may not be your saw):
http://www.ordertree.com/modelinfo/MCC/21-600035-59-Mac-3516-IPL-211318-01/139.21-600035-59-Mac-3516-IPL-211318-01.1.59.1.html
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
If the above is not your saw, yours can be located here:
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
A typical fuel system and a couple of tips follow:
If properly plumbed your saw will run with the carburetor to primer hose capped off.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
3/14/2010 12:54:47 AM • McCulloch 10"... • Answered on Mar 14, 2010
McCulloch 10" Electric Pole / Chain Saw Logo
35 questions posted
Top McCulloch Garden Experts
Jay Finke
Jay Finke
Floyd Rogers
Floyd Rogers
Level 1 Expert
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
View Most Popular
McCulloch Garden
  • McCulloch Garden
Most Popular Question
need info poulan pro 445 fuel line
  • Garden
