20 Most Recent
Wmh Tool Group JET 710750 JWBS - 18X 18" Wood Bandsaw with 12" Capacity and 1 - 3/4 HP Motor Questions & Answers
Can i replace my 30mm arbor.
If you cannot get an adaptor to do what you want it is probably because the machine is designed to run with the fitting for 30mm arbor . If you down size the implement it affects the power required and may damage the motor or make the unit dangerous to operate
6/11/2013 10:38:12 AM •
Saws
Answered
on Jun 11, 2013
Why my Makita disc cutter has spark wont start
If the fuel in it is 2 or more months old dump it out and put in fresh fuel and try statring. Also try try a squirt of starting fluid into the carb. If it fires on it you may need to do this a few times to pull the old fuel in the lines through till the fresh fuel can get to the carb.
4/10/2024 4:13:02 PM •
Saws
Answered
on Apr 10, 2024
