20 Most Recent
Technical Pro RX55URIBT Professional Receiver with USB & SD Card Inputs and Bluetooth Compatibility, 1500 Watts Peak Power Questions & Answers
I cannot bring up the volume to pass 20 if i bring it up higher it shuts off
Check that the speakers are the same impedance as the amplifier is rated for and that the speaker wires or connections are not shorted. It sounds like you are trying to drive 4 ohm speakers with an amp that is rated for 8 ohms - it will work at low volumes, but will overheat and shut off if you try to drive it too hard (higher volumes)
Audiosonic CR-06PL not changing time when following manual instructions.
Set Time Hours and Minutes: Press Time/12/24 and Alarm1/ON/OFF buttons at the same time for two seconds and it will start to blink the hour.
Press and hold the button for a fast setting or tap it briefly to increase the setting by one hour. Now set the minutes with time (press and hold) and min.
How do I set the Audiosonic clock? Set current time Press and hold the time button and simultaneously press the hour to set the hours in 24-hour mode .
