20 Most Recent
Dewalt DG2900 Heavy Duty 2900 Watt Gas Generator Questions & Answers
Won't start, checked spark plug, turned engine
make sure unit has oil.some of them have low oil switch which will not let it run or start usually if it has triggered the low oil switch to open you have to reset it manually by pushing it in.also check that you have turned on the fuel .
Only getting 4vac output on a DG2900 generator
You need to use a Voltmeter and go right to the Output Terminals on the Generator, Disconnect anything from them, and measure that Open Circuit Voltage. If it is OK there, then the conditioning circuitry AFTER that is faulty. BE CAREFUL.
How do I unseiz my dewalt DG6000 generator motor due to non use
Remove spark plug. Pour a small amount of a lubricant like Marvel Mystery Oil in and allow to soak for a day or two. Repeat this process at least two times. Then try to turn the engine over slowly by hand. Do not use the pull rope or starter. You need to use a wrench, pry bar, etc. You may have to remove the engines cover to access the flywheel to turn it.
10/7/2016 11:03:53 PM •
Dewalt...
Answered
on Oct 07, 2016
Gas in oil on dewalt generator
It's your carburetor. You'll have to clean it out, rebuild it, or buy a new one. The float pin is getting stuck so it's either the float or dirt inside. Make sure you turn the gas off after each use of your generator or it will eventually happen if there's dirt in the tank. Don't forget to change out the oil before you start it again or you'll have fireworks.
5/28/2015 12:10:28 AM •
Dewalt...
Answered
on May 28, 2015
