20 Most Recent Cuisinart ICAPP-4 Questions & Answers
5answers
I need instructions for a Cuisinart Iced Cappuccino Maker
I have a PDF of the user manual if you want me to e-mail it to you. In the meantime, here is my Wiki Manual (BTW, pagan, the machine does make hot espresso or cappucino, but it doesn't froth per se like a regular espresso machine - it just heats the milk internally and dumps it into the espresso):
General Directions for Making Iced Cappuccinos
- Place carafe on top of drip/tray grate with handle touching right front of ICAPP – the ice fill lines should be visible when looking at front of unit
- Turn “milk knob” to OPEN position, and open lid of ICAPP
- Remove milk container, espresso collector, espresso spinner cup and cover
- Put espresso collector back in place with two plastic teeth facing front of machine
- There is a stepped fill line inside water reservoir that measures off 1,2, and 4 cups
- Fill water reservoir with either 1,2 or 4 fill line cups – do not overfill to avoid damaging the electronics
- Add espresso grounds to espresso spinner cup
- Line up teeth of spinner cup cover with spinner cup so that the cover locks into place
- Fill milk reservoir with 3 oz of milk per cup of iced cappuccino that you plan to make – there is a fill line that measures off 2 cups or 4 cups
- Fill carafe with either 2 cups worth of ice or 4 cups, depending on how much iced cappuccino you plan to make
- Press down on lid and turn milk knob to HEAT postion
- Turn ICAPP on using the ON/OFF button – it will begin to heat – takes about 5-6 minutes (HEAT light will stay on during this process – doesn’t make noise or steam for several minutes)
- When READY light turns green, turn the milk knob to the DISPENSE MILK position – your espresso and milk will start dispensing
- Unit turns itself off automatically when ready – takes several minutes
11/30/2019 9:47:36 PM • Cuisinart... • Answered on Nov 30, 2019
tip
Other Notes on The ICAPP-4
Notes
- the whole process of making iced cappuccinos from the time you press the ON button until the unit shuts off automatically takes about 10 minutes
- once you press the ON button, the unit does not make a sound for several minutes – be patient
- remember to position the carafe so that the handle touches the right front of the unit, and the spout touches the left front of the unit – critical for smooth milk/espresso admixture/ramping
- clean the removable parts after every use to avoid damaging your ICAPP
- once a month, run a decalcification process – simply pour 2 tbsp vinegar on a damp cloth, wipe the water reservoir, and then run a cycle of water – ostensibly, the vinegar residue should be enough vinegar for the decalcification process – newer Cuisinart coffee and espresso makers often recommend a specific portion of vinegar and water – not so with this unit
- several of the instruction book’s recipes call for adding sugar or flavored syrup – remember to add them AFTER the cappuccino is made, directly into the carafe – do not pour sugary ingredients into the inside of the machine, or you will have a sticky mess on your hands
- parts are no longer available for this model through the company directly; all units are out-of-warranty because of the age of the product; but several of the cappuccino and espresso recipes are still available at Cuisinart’s website
- if you are missing parts for the unit, I would buy one – broken or otherwise – from an independent seller, eBay, etc who has the part you need
on Feb 25, 2009 • Cuisinart ICAPP-4
tip
ICAPP-4 - A Wiki Manual
Cuisinart ICAPP-4 – Iced Cappucino and Hot Espresso Maker – A Wiki Manual
By Tha Mp3 Doctor (who also loves Cuisinart)
Since I am not well-versed in the copyright laws regarding reprinting copies of standard user’s manuals online, I am writing this Wiki Manual for the ICAPP-4. My unit is 12 years old (in 2009) and continues to run strong through two different owners.
My Cuisinart CCJ-500P1 won't turn on how to repair
To repair it, one must find out what the cause is. Do some fault finding first; check there is power at the switch and the motor has continuity etc. When you have found the faulty part, then you can replace the faulty part or repair the break in the cable etc.
2/4/2024 4:45:29 PM • Cuisinart Coffee... • Answered on Feb 04, 2024
Cuisinart DCC-3000C coffee maker. I want to stop the chime on my Cuisinart DCC-3000C coffee maker which does not have a 'Tone' button. How do I do it?
Question edited for clarity. Unfortunately you can't. The chime sounder is part of the main control board. Next time you take it in for dealer servicing, ask if they can muffle it with some silicone. Or upgrade to the DCC-3200 model ..
1/20/2024 9:22:30 PM • Cuisinart Coffee... • Answered on Jan 20, 2024
Cuisinart coffee maker.... clock light does not light
Switch it off and wait 10 minutes: Sometimes, if your coffee maker is still new and has water sitting in it for a long time, or if you have just cleaned it, you might see an error message saying that there is no water. Just turning them off and waiting 10 minutes will often solve the problem. Afterward, turn it back on, pour some water into it and try again! If for some reason it doesn't work after doing that, try the next steps mentioned below. Reset the clock, then brew a cup of coffee: Check to make sure all of your connections are properly secured and tight. Even a half-turn can cause problems with appliances that use electricity, and it is important to remember not to force any connection into place. You may need a new plug for an appliance that's been in service for many years if you are having trouble getting power to it-don't assume anything! Many older appliances have worn or damaged wiring. Turn it off and on again: The next logical step is to turn your coffee maker off and then back on again. This works with many small appliances and just might clear up whatever issue you're experiencing. In some cases, a reset button or power button will be present to make it easier. If not, try to turn it off at its power source (i.e., unplugging it) and then plug it back in afterward. If that doesn't work, try turning off your home's circuit breaker for a few minutes, if applicable, before returning power to it and trying again. If these tips do not work, you might try the customer service of the manufacturer.
12/30/2023 5:52:16 AM • Cuisinart Coffee... • Answered on Dec 30, 2023
My Cuisinart Grind and Brew does not brew. Cannot clean or descale since the water or solution does not pass thru.
Check Water Reservoir: Ensure that the water reservoir is properly seated in place and filled with water to the appropriate level. Sometimes, the machine won't brew if it detects an inadequate water level. Check Water Inlet and Outlet: Inspect the water inlet and outlet for any clogs or blockages. Sometimes, debris or mineral buildup can prevent water from flowing through the machine. Clean any visible obstructions carefully. Descale the Machine: If the issue is due to mineral buildup, descaling the coffee maker might help. Use a commercial descaling solution or a mixture of equal parts water and white vinegar. Run this solution through the machine as you would during a regular brewing cycle. Afterward, run a few cycles with plain water to rinse out any residue. Inspect Grinder and Filter Basket: Check the grinder and filter basket for any coffee grounds or other debris that might be obstructing the flow of water. Ensure that the grinder and filter basket are correctly positioned and securely locked in place. Clean the Brew Head: The brew head may also become clogged with coffee grounds or oils, affecting water flow. If your machine has a removable brew head, take it out and clean it thoroughly. If it's not removable, follow the manufacturer's instructions for cleaning the brew head. Run a Cleaning Cycle: Some coffee makers have a cleaning cycle that helps remove buildup inside the machine. Refer to your user manual for instructions on how to activate the cleaning cycle. Reset the Machine: In some cases, a simple reset can resolve minor issues. Turn off the coffee maker, unplug it from the power source, wait for a few minutes, then plug it back in and try brewing again. Check the tubes: Make sure the tubes are sitting in the right place and filled to the correct level. Sometimes the machine will not make alcohol if it senses that there is not enough water.
8/3/2023 4:58:20 PM • Cuisinart Coffee... • Answered on Aug 03, 2023
Cuisinart DCC-3200C 14-Cup Programmable Coffeemaker. I successfully made coffee in my DCC-3200 for 3 mornings. This am I got only hot water and the grounds were dry. How could it be clogged already?
Question edited for full 'make model (what it is)'. Question moved to maker category. this is a very simple 'drip though a filter, pour and serve' machine. You must have forgotten to put the coffee and filter in. It is easy to do and I have done it at least three times in 20 years. If you got hot water, the heater is working, if the grounds were dry, the water didn't spray over them. My sunbeam coffee maker won't let that happen. https://www.google.com/search?q=DCC-3200 ..
7/5/2023 3:58:14 AM • Cuisinart Coffee... • Answered on Jul 05, 2023
2answers
Cuisinart DGB-900bc clean basket notice won't turn off.
I also own a Cuisinart DGB-900BC. This is how I fixed the sensor issue.Disclaimer: IF YOU ARE UNSURE OF MY INSTRUCTIONS USE A MULTIMETER OR TESTER TO ENSURE YOU AREN'T MODIFYING THE WRONG WIRES WHICH COULD RESULT IN ELECTROCUTION IF DONE IMPROPERLY.Over time the basket tends to sag, which prevents the little sensor from contacting it for the unit to realize the door is shut. The sensor is a spring loaded piece of plastic hanging from the underside of the coffee maker which makes contact with the basket when it closes. If you're looking straight on it is to the left.What you'll have to do is either find a way to fix the basket sag, force the sensor closed, or do what I did and modify the unit.Sensor modification:You will need a size 10 security bit with the hollow center (not just a plain star bit) screwdriver to take the four screws out of the bottom to reveal the wires you need to modify. There are two blue wires that go to the top of the unit which are crimped onto two black wires. The two black wires lead to the circuit board which is extremely difficult to get to on this model. All you have to do is snip those two black wires and install a push button which keeps the circuit closed until you push it. Initially I thought twisting them together would work but this unit will not brew coffee a second time unless you remove the basket and toggle the sensor input. So I basically have to unplug the unit and plug it back in to reset that. I will be adding the push button soon.Ensure you buy the right push button. You need one that keeps the circuit closed until you push it, most push buttons keep the circuit open until you press them. Alternative is to buy a metal toggle switch, preferably one that spring loads back to the center after you push it.To summarize:1) Fix basket sag or wedge sensor to closed position.OR1) Remove bottom plate of coffee maker2) Snip the blue wires leading to the sensor and add a push button or toggle switch on the two black wires they were connected to. Mount switch externally so you can push it to fool the unit to think you removed and replaced the basket.My attached picture shows my temporary twisted wire solution with yellow connector before I added the push button. Note that while I'm holding the blue ones leading to the sensor, the two small black wires are what's important. I did this modification before making an account here.20230626_225346-b5oikuwgyissowxaundqdeik-d-0.jpg
6/28/2023 1:00:12 PM • Cuisinart Coffee... • Answered on Jun 28, 2023
There is a gap from which the coffee sprays out at the top of the bin where coffee is supposed to go. The gap is almost 1/4 inch
I got one of these secondhand. I knew it was missing the lid for the hopper, which I wasn't concerned about; I did not realize it was *also* missing the lid for the catch bin, which appears to have been your issue as well. Commenting in case anyone else runs across this. I've reached out to Cuisinart and am hoping they can just send me a replacement *lid* for the bin because replacing the whole bin lid and all wouldn't be worth it.
4/11/2023 12:13:23 PM • Cuisinart Coffee... • Answered on Apr 11, 2023
2answers
My cuisinart coffee maker shuts off after brewing cycle. What. Do I do to fix this oroblem
Believe it or not, this frequently happens when there is calcium scale build-up in your coffeemaker's water line. The coffee make will make it through the brewing, but then shut off if it thinks the flow was too slow--which is nearly always due to built up calcium scale. All you have to do is run a few pots of white vinegar through your coffeemaker to get all the scale out of the waterline; I'll usually mix half water, half white vinegar and run the brewing cycle (no coffee in it, obviously). You'll see the scale come out in your coffee filter. You can run the same pot of water-vinegar mix several times, and then run a couple of extra pots of *fresh water only* to rinse out the descaling vinegar mix from the water line. Voila! your coffeepot will start working again just like it should.
2/26/2023 3:57:34 AM • Cuisinart Coffee... • Answered on Feb 26, 2023
The grinder on my Cuisinart DBG-600 coffee maker won't shut off
It is not a well known issue. There is general help in the link. https://www.google.com/search?q=Cuisinart+DBG-600+coffee+maker+grinder+won%27t+shut+off ..
2/26/2023 2:28:06 AM • Cuisinart Coffee... • Answered on Feb 26, 2023
2answers
Cuisinart model DCC-690. Water filter for it please?
I'm sorry to hear that you're having trouble finding replacement water filters for your Cuisinart DCC-690 coffee maker. After some research, it appears that the DCC-690 model does not have a specific water filter that is designed to fit it. However, Cuisinart does offer a universal water filter that can be used with any of their coffee makers. The Cuisinart DCC-RWF replacement water filter is a universal filter that is compatible with all Cuisinart coffee makers that have a water filter. It is designed to remove impurities from tap water, such as chlorine, calcium, and other minerals, to improve the taste and quality of your coffee. You should be able to find this filter on Cuisinart's website, or at a retailer that sells Cuisinart coffee makers and accessories. It is important to note that the filter should be replaced every 60 days, or after brewing 60 pots of coffee, whichever comes first. I hope this helps!
2/24/2023 4:56:22 AM • Cuisinart Coffee... • Answered on Feb 24, 2023
Cuisinart brewer gauge stuck on full. Coffee on demand DCC-3000.
After repeated attempts to fix our Cuisinart coffeemaker gauge, I noticed a metal mechanism in a grooved area at the inside front of the coffeemaker. I was able to push it up and down, which caused the level indicator needle to go back and forth between empty and full. Determined that the hook at the front of the coffee reservoir matched up with this mechanism. There wasn't enough tension in the hook to depress the metal mechanism. Ordered part #DCC-3000CR for my coffemaker model through Cuisinart.com. Just installed the new coffee reservoir and the gauge now works! 59161ab5-eaa1-4ecc-bfb0-5a1e457c5a97-hewvoa2optjiizonipsnfh5i-d-1.jpeg 59161ab5-eaa1-4ecc-bfb0-5a1e457c5a97-hewvoa2optjiizonipsnfh5i-d-0.jpeg a6a29666-5006-4d9d-b6d4-93ebdf51562b-hewvoa2optjiizonipsnfh5i-d-3.jpeg a6a29666-5006-4d9d-b6d4-93ebdf51562b-hewvoa2optjiizonipsnfh5i-d-2.jpeg a6a29666-5006-4d9d-b6d4-93ebdf51562b-hewvoa2optjiizonipsnfh5i-d-4.jpeg
1/5/2023 11:35:10 PM • Cuisinart Coffee... • Answered on Jan 05, 2023
I have a little white float inside the water chamber that keeps getting stuck in my Cuisinart coffee maker
In the first instance you can try cleaning and descaling it. The whole tank with float is available as a spare pare if this is your model. https://www.google.com/search?q=cuisinart+coffee+maker+float+replacement ..
1/1/2023 11:45:37 PM • Cuisinart Coffee... • Answered on Jan 01, 2023
Cuisinart DGB-625. Moisture is getting inside my coffee grinder during the brewing process in my DGB-625 Series Grind and Brew Coffee Maker. Is this normal?
Question edited for clarity, add maker. Question moved to maker category. February 9th was my birthday. :>D No the grinder should always stay dry. ..
12/19/2022 9:19:01 PM • Cuisinart Coffee... • Answered on Dec 19, 2022
How do I fix a Cuisinart EM-25 Espresso, Cappuccino & Latte Machine that keeps saying add water please?
Take it in for service. There will be a water level sensor that has failed.
12/13/2022 6:23:07 AM • Cuisinart Coffee... • Answered on Dec 13, 2022
Cuisinart ICAPP-4 Logo
5 questions posted
Top Cuisinart Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
john h
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Cuisinart Coffee Makers & Espresso...
  • Cuisinart Coffee Makers & Espresso...
Most Popular Question
need instructions cuisinart iced
  • Coffee Makers & Espresso Machines
