20 Most Recent Milwaukee 2610-20 18V Cordless M18 High Performace Drill/Driver Questions & Answers
I have a Milwaukee M18 cordless drill with a bit broken off inside and the chuck won't open.
Put your drill into reverse, and hold the chuck. With luck, that will loosen the chuck and the broken bit will fall out.
7/17/2015 11:53:32 PM • Milwaukee... • Answered on Jul 17, 2015
Were can I find schematics for drill gun????
http://www.us.hilti.com/holus/page/module/product/prca_catnavigation.jsf?nodeId=-71302
4/11/2012 6:56:25 PM • Milwaukee... • Answered on Apr 11, 2012
What does the even numbers
These are the torque settings so you can sink the screw to the depth that you want it Thank you
6/11/2011 12:57:25 PM • Milwaukee... • Answered on Jun 11, 2011
Do you stock brushes for Milwaukee S18TX cordless.
try parts direct or replacement parts on the net.
8/30/2010 12:01:53 PM • Milwaukee... • Answered on Aug 30, 2010
Milwaukee 1/2 lithium ion 18v drill not working
I have the same problem and its about a year old too.
12/15/2009 9:36:10 PM • Milwaukee... • Answered on Dec 15, 2009
Looking for parts list for Milwaukee 2610-20
Hi, this website has parts diagram for your tool.
Hope this helps.
http://www.ereplacementparts.com/milwaukee-261020-ser-b53a-volt-magnum-1234-driverdrill-parts-c-131_5138_16331.html
8/18/2009 9:33:43 PM • Milwaukee... • Answered on Aug 18, 2009
I need instructions on how to wire a new switch to an old drill; Milwaukee Magnum s/r 053242842. Listed 480A
These videos should help, they all work to a theme.
7/21/2023 11:07:57 PM • Milwaukee Drills • Answered on Jul 21, 2023
Which side is hot and which side is ground on a 9.6 volt 18 volt Milwaukee universal charger?
There is help and videos in the link, but you can easily check the contacts with an analogue multimeter. You don't say WHY you want this information? https://www.google.com/search?q=18+volt+universal+charger+milwaukee+wiring+diagram ..
4/4/2023 3:19:09 AM • Milwaukee Drills • Answered on Apr 04, 2023
How do I take out the spindle on a 1675-1 Milwaukee hole hawk drill
To remove the spindle on a Milwaukee Hole Hawg 1675-1 drill, you will need to follow these steps:
  1. Disconnect the drill from the power source and remove the chuck key.
  2. Turn the drill over so that the chuck is facing upwards.
  3. Locate the spindle lock button on the side of the chuck.
  4. Press the spindle lock button and hold it down while rotating the chuck counterclockwise to loosen it.
  5. Once the chuck is loosened, you can remove it from the spindle by pulling it off.
  6. To remove the spindle from the drill, you will need to loosen and remove the retaining bolt that holds it in place. The retaining bolt is typically located on the bottom of the drill, near the front of the spindle.
  7. Once the retaining bolt is removed, you should be able to lift the spindle out of the drill.
It is important to follow these steps carefully to avoid damaging the spindle or the drill. If you are having difficulty removing the spindle, you may need to consult the owner's manual or a certified mechanic for assistance. They will have the necessary tools and expertise to help you remove the spindle safely.
1/8/2023 5:07:44 AM • Milwaukee Drills • Answered on Jan 08, 2023
My Milwaukee cordless drill has a full battery and the trigger works and the truck works but it won't turn right or left at all
How did we go from a Cordless drill and battery to the steering on a truck?? :>D
12/6/2022 7:17:04 PM • Milwaukee Drills • Answered on Dec 06, 2022
How do i replace the spindle assembly in my milwaukee 0235-1 drill ?
copy and paste https://www.jackssmallengines.com/jacks-parts-lookup/manufacturer/milwaukee/electric-drill/0235-1-serial-755-70423-milwaukee-electric-drill-driver-parts/1-2-keyless-chuck-magnum-drill
6/30/2022 4:46:56 AM • Milwaukee Drills • Answered on Jun 30, 2022
I have Milwaukee m18 drill that won't tighten down.
There are some youtube videos on how to replace the chuck and there are several sources for chucks.
4/23/2022 10:29:16 PM • Milwaukee Drills • Answered on Apr 23, 2022
2answers
I have a Milwaukee cordless drill/ driver cat#2801-20 will not work but the flash light will work
The battery is not fully Charged. Please charge for 4 to 5 hours. The flash light works because it requires lower voltage than drill/driver to work.
3/9/2022 9:39:23 AM • Milwaukee Drills • Answered on Mar 09, 2022
How to clean M18 milwaukee impact
Tec7gt7 ( recommend spray ) electrical safe for switch and motor commutator. for novice and expert. do not use wd40. Use if very dirth A cold degreaser for only cleaning the 2 housing parts
9/16/2020 9:03:25 AM • Milwaukee Drills • Answered on Sep 16, 2020
Milwaukee 2610-20 18V Cordless M18 High Performace Drill/Driver  Logo
20 questions posted
Top Milwaukee Drills Experts
vince
john h
Are you a Milwaukee Drill Expert? Answer questions, earn points and help others
View Most Popular
Milwaukee Drills
  • Milwaukee Drills
Most Popular Question
looking parts list milwaukee 2610 20
  • Drills
