20 Most Recent Cuisinart DGB-300 Coffee Maker Questions & Answers
How do I remove the filter basket from Cuisinart Programmable coffeemaker CBC-5200PC Series?
I have this coffee maker and the basket comes out with the grinding cup and assembly. It's all one piece and pulls straight up. You may need to pull a bit harder.
6/11/2014 10:57:10 AM • Cuisinart... • Answered on Jun 11, 2014
2answers
The grinder motor does not turn on when i start
Make sure you have the dial that sits on top of the filter basket turned to the open hole. Otherwise, it will not grind as it can not send the coffee grounds into the basket.
3/7/2014 3:51:12 AM • Cuisinart... • Answered on Mar 07, 2014
0answers
0answers
0answers
0answers
2answers
I am looking for the
You may be able to order a replacement grinder basket online from the following site:
http://www.abtecparts.com/cuisinart_coffeemaker_baskets.htm
Thank you for using FixYa!
8/14/2012 2:07:11 PM • Cuisinart... • Answered on Aug 14, 2012
Need replacement lid for Cuisinart DBG300
I believe your model is actually the DGB300. Available replacement parts can be ordered online from Cuisinart at:http://www.cuisinart.com/discontinued/coffee_bar/dgb-300.html Unfortunately it may be necessary to order the complete carafe. You may wish to try contacting Cuisinart using their web inquiry form to see if they are able to provide the lid as a separate part:https://www.cuisinart.com/support/international.html
1/20/2012 5:46:54 PM • Cuisinart... • Answered on Jan 20, 2012
DGB-300
Definitely do the vinegar/water cleaning. It will almost undoubtedly resolve your issue.
5/18/2011 1:41:34 AM • Cuisinart... • Answered on May 18, 2011
The grinder on my dgb300
Hello
Open the water reservoir of your Cuisinart coffeemaker and fill it with water using the coffeemaker's carafe. If you forget to add water to the coffeemaker, the brewing cycle will not start.
Turn off the auto start feature on your Cuisinart coffeemaker if the brewing cycle does not begin when desired. If the coffeemaker is programmed to brew at a specific time, the light near the "Program" button will be lit. Press the "On" button to override the programming and begin brewing immediately.
Program the automatic brew start time by pressing the program button on the control pane. Set the brew start time with the hour and minute button and allow the program mode to reset to normal time after a few seconds.
4/16/2011 8:25:29 PM • Cuisinart... • Answered on Apr 16, 2011
2answers
The motor on my Cuisinart DGB-300 Coffee Maker
HI,
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.You need to replace it.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
11/3/2010 11:48:52 PM • Cuisinart... • Answered on Nov 03, 2010
Cuisinart DGB-300 Coffee Maker Logo
44 questions posted
Top Cuisinart Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
john h
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
DGB Cuisinart
  • DGB Cuisinart
Most Popular Question
grinder motor not turn when start
  • Coffee Makers & Espresso Machines
