20 Most Recent
Cartier Tank Francaise W51001Q3 Wrist Watch Questions & Answers
Is my watch authentic?
no need for serial number- look on the dial, if the 'x' marking the ten o'clock has 'cartier' written on it, your watch should most definately be authentic.
I have a Cartier Tank
replace the clasp, I see it all the time in this model watch. I usually charge $50.00 for the clasp for these watches, It can be adjusted but it will loosen within the next year or less.
Cartier Women's Tank Watch
What has been the issue when the repairs have been done? My experience with Tanks is that any reputable watch shop will replace the battery for $20. I don't know why it has cost you so much, but if the model you have is an auto-winder, then there is no way to retrofit a battery - although for $600 someone may be able to change the internal watch out completely.
My cartier tank francaise watch stopped working
If your watch is automatic, then it is self winding and should start if you gently shake it from side to side a few minutes.
Automatic watches do thrive on being worn every day and if left unused will stop after a few days.
If it is a quartz watch, then take it back to the vendor and ask them to fix it.
I got it as gift,
You have to pull on the back of the bracelet in the middle. You feel like you are going to break it but you won't. Pantheres are especially hard to open because you can't tell where the links go together. Try pulling on one side of the middle part then the other, one side is usually the weaker one then once that one opens, you can put your fingernail under the other side and pull it open. It's crazy how they don't have a button or something to open them like other watches. You can do it!
I haven't worn in so
Just pull on it in the back...there are no clips or buttons..its weird the way they open, it feel like you are going to break it! One on the two sides will come open easier than the other so try both sides. Good luck.
Is this cartier watch authentic
Nobody can tell you this by the number only exept Cartier itself.
Follow this link, enter details and ask questions directly to Cartier:
http://www.cartier.com/en_na/Cartier
Rate me, please.
Set date on Cartier Tank Francaise Chronoflex
- click the top button
- click the bottom button to reset the timer
- pull the crown out all the way
- twist the crown forward hard and fast for a few seconds. The minute hand will start advancing very quickly.
- when the desired date and time is reached, push the crown back in place. If you missed the time, pull the crown back out and twist backwards. The minute hand will move slowly in reverse. If you twist hard and fast, the minute hand will start spinning in reverse again.
How do I cahge time on french tank
- click the top button to stop the second hand
again.
