20 Most Recent
DeLonghi DDH30 Dehumidifier Questions & Answers
My delonghi dem 10 dehumidifier is working and collecting water but but the pause is continuously flashing why is this
The flashing pause light on your DeLonghi dehumidifier indicates that the unit is in a defrost cycle. During this time, the compressor shuts off and the fan continues to run in order to thaw any ice that may have formed on the coils. This process typically lasts for 10-15 minutes before the unit resumes normal operation.
If the pause light continues to flash even after the defrost cycle is complete, it may indicate a problem with the unit's sensor or control board. In this case, it is recommended to consult the user manual or contact a professional for assistance with troubleshooting and repairs.
2/26/2023 2:11:51 PM •
DeLonghi...
Answered
on Feb 26, 2023
DELONGHI DH300P E3
The E3 Code, indicates that the air intake filter needs to be removed and cleaned. Be sure the unit is OFF and unplugged before removing the filter. Filter cleaning should be performed at least once every two weeks, as part of Routine Maintenance.
6/6/2020 6:44:27 PM •
DeLonghi...
Answered
on Jun 06, 2020
My DeLonghi DEM10 wont power on any more - like fuse gone
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
5/16/2019 10:55:04 AM •
DeLonghi...
Answered
on May 16, 2019
De longhi dehumidifier showing yellow light
Usually happens when the float valve is stuck in the down or up position try wiggling the handle to release or if the collection bucket is not sitting perfectly on the safety switch has to be down square I have the delonghi dem10 model always empty and unplug before checking
1/31/2019 4:45:46 PM •
DeLonghi...
Answered
on Jan 31, 2019
Good morning.
I have a DeLonghi
Are you worried as to why there is no Water in the Water Tank/Bucket at all?
Well, a few operational basics must be understood by you please.
For the unit to remove moisture from the air and draw water into the bucket/tank, the set relative humidity (%RH) must be below the current or ambient room relative humidity.
Attempt to lower or reduce the setting you have to a lower value and it should start collecting water in the tank.
Hope this helps
11/20/2017 11:49:11 AM •
DeLonghi...
Answered
on Nov 20, 2017
Dh25 the cooling coils get frozen,the appliance sill working even the canister is full.
The normal operating temperature is above 65 F. Much below unless specially designed for low temperature they will freeze up.
They have a frost detector and will defrost but it is very inefficient and not practical. My experience they eventually form a block of ice on the coils. They heat the room in the process so in a moderate area they can raise the temperature and provide needed circulation.
In the past where the temperature is cool I have faced the output into a corner, raised it off the floor and once the unit got started the heat created from the unit kept the air warm enough to avoid freezing up the coils.
Always check for recalls. Some models have had problems and have been recalled. See the link below.
Gree Reannounces Dehumidifier Recall Due to Serious Fire and Burn Hazards...
Hope this has helped?
1/13/2016 12:51:50 PM •
DeLonghi...
Answered
on Jan 13, 2016
