20 Most Recent DeLonghi AR1070 Oven Questions & Answers
manual
AR1070 Oven Manual
DeLonghi OvensUploaded on Oct 24, 2013
0answers
Where can I get a replacement flame sensor for my DeLonghi DEBIG24ss model oven?
notify manufacturer for distributor / parts --appliance repair shop --online search
11/22/2023 7:02:24 PM • DeLonghi Ovens • Answered on Nov 22, 2023
DeLonghi DEBIG24 Thermocouple replacement
The Thermocouple is in the flame of the pilot light and is connected to the main burner valve. It is a gas appliance and should only be worked on by a registered, gas certified technician. Yes, the oven has to come out unless there is a removeable panel at the front bottom edge. https://www.google.com/search?q=DeLonghi+DEBIG24+Thermocouple+replacement ..
11/10/2023 9:34:40 PM • DeLonghi Ovens • Answered on Nov 10, 2023
Help with Calibrating Electric Oven Temps with digital controls?
The thermostat is mechanical using pressure from a waxstat style sender and is not adjustable. I expect you are measuring with your probe in a different place to the sender unit; hence the differences.
11/8/2021 7:54:16 AM • DeLonghi Ovens • Answered on Nov 08, 2021
I have replaced my Delonghi fan bake element but it still will not heat up
Check it with a test meter. Then test the control switch to it.
10/4/2021 8:57:06 PM • DeLonghi Ovens • Answered on Oct 04, 2021
The electrical oven of our DEF908A is not working despite being wired up by an electrician, is this becasue the gas is not yet installed?
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times: 1.Home breaker flipped or the fuse blown? Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary. 2.Power cord plugged in?Grab the plug and wiggle to determine a good connection. 3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires. 4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board. 5. 6.Even a bad relay door switch will hinder your oven from operating. If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse. THINGS TO CHECK: the broil element is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage. If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms The bake element is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off. Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms The oven safety valve (also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter. I offer free advice bcuz God is so good! Surface burners are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter. You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals. On modern electronic control ranges, the oven temperature sensor is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test. The infinite switch on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch. 1.If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons. (Locate the suspect switch for testing. Label all wires and terminals before disconnecting. A close up digital photo may be helpful. 2.On the burner control switch the terminal labeled "P" leads to the burner indicator light. The terminals labeled "H1" and "H2" lead to the burner element and the terminals labeled "L1" and "L2" (sometimes "N1" and "N2") are the power supply wires. 3.Set your multimeter to ohms setting x1. Turn the burner control to the highest temperature setting. Place one probe on pin "L1" and the second probe on pin "H1". The resistance measurement should be very low, zero to twenty ohms. If the test shows high or infinite resistance, the burner switch is defective. 4.Repeat the step above for the terminals "L2" and "H2". 5.If the control passes that test, turn the temperature setting to about the middle of the range and repeat the previous two steps. This will test for an intermittent problem with the switch. If the test does not show continuity with very low resistance, the switch should be replaced. 6.With the switch turned to the "Off" position, the resistance on each of the pairs of terminals tested above should now show no continuity or a reading of infinite resistance. 7.A test for continuity between "P" and "L1" when the burner control switch is on should show continuity. The light should be on whenever the control is turned on. If your test shows continuity, but the light does not operate, it is likely the bulb has failed. If the burner switch shows high or infinite resistance, the switch is not passing along current to the burner and so the switch should be replaced. ) Most modern ovens use an electronic control board to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced. The oven burner igniter commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on- fuse location oven fuse_ranger_17-undefined-undefined-0_0.jpg fuse module with words-undefined-undefined-2.jpg ignitor connectia_04-undefined-undefined-5_0.jpg infinite switchs stove-undefined-undefined-7.jpg
8/18/2021 8:28:32 AM • DeLonghi Ovens • Answered on Aug 18, 2021
DeLonghi EDB 475 ST Bottom oven not working. Clock is on, and fan is working, but no heat. Upper oven OK and working correctly.
Have you checked if the heating element is getting hot ? Fair chance you need a new one.
12/16/2018 2:52:42 PM • DeLonghi Ovens • Answered on Dec 16, 2018
How to clean the grill element in an electric
have same problem with grill smoking,try barry coates method if this works to stop from happening again there should be a tray that comes with most ovens,flip this over and put on top rack,should stop this problem,then place foil on bottom of oven to catch any spills or buy another tray.. all the best tony gilchrist....
10/8/2018 9:00:31 AM • DeLonghi Ovens • Answered on Oct 08, 2018
I need intructions for dismantling DeLonghi EO400 toaster oven
1-800-126659 is customer support number for DeLonghi in Australia.
8/10/2018 7:35:17 PM • DeLonghi Ovens • Answered on Aug 10, 2018
DELONGHI OVEN DOOR HINGES DEFSGG 36 SS
What about the oven door hinges?
3/16/2018 12:43:12 AM • DeLonghi Ovens • Answered on Mar 16, 2018
How to change lower element in DeLonghi Airstream Convectio Oven
  • How to change lower element in DeLonghi Airstream Convectio Oven??
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • 10/28/2017 6:44:35 PM • DeLonghi Ovens • Answered on Oct 28, 2017
    DeLonghi AR1070 Oven Logo
    3 questions posted
    Top DeLonghi Ovens Experts
    john h
    ADMIN Andrew
    ADMIN Andrew
    Are you a DeLonghi Oven Expert? Answer questions, earn points and help others
    View Most Popular
    DeLonghi Ovens
    • DeLonghi Ovens
    Most Popular Question
    delonghi edb 475 st bottom oven not
    • Ovens
