20 Most Recent
Fowler 0-1" ELECTRONIC MICROMETER # 54-850-001 Questions & Answers
Where/how do you make a calibrated adjustment on a
Take a piece of paper, insert it between the measuring faces close the instrument using the friction spindle. slip the paper out from the measuring faces. repeat until the paper comes out clean on both sides. Close the instrument using the friction spindle. zero the unit. check the instrument on a calibrated standard like a gauge block or mic standard. It should be right on the money. As far as I know that is the only adjustment required.
Need user manual for w5746
Same exact features, buttons and functions as this manual by Irwin.
http://www.irwin.com/uploads/documents/36_laser_tape_25.pdf
Will one of the newer sensors work in place of my 1457 sensor?
It's possible that one of the newer sensors could work in place of your 1457 sensor, but it depends on the specifications of the newer sensors and the compatibility with your base unit. The I MAX1457 sensor, which is a highly integrated analog-sensor signal processor optimized for piezoresistive sensor calibration and compensation. However, I have no information about its compatibility. If you're looking for a replacement sensor, I suggest contacting the manufacturer of your base unit to inquire about compatible sensors. Alternatively, you can check the user manual of your base unit to see if it lists compatible sensors. Garage door opener sensors are not universal. Safety sensors can only communicate with garage door openers from the same brand.
