20 Most Recent
RTO 110cc Basic Manual ATV # ATD-125C Questions & Answers
Chinese 110cc atv won't start fuel good no signal to coil
there is a little black box with 6 wires 5 of them used on the left side of the frame in the front try that but if the plug in the back is un hooked or not working follow the wire from the bail cord socket and unplug it and put a wire between the two prongs that would eliminate that issue from the bail cord switch hope this works for you
Does anyone know how to set the idle on the 110 atv
Not sure about that particular one however if it has been sitting for a while or has a bad fuel filter the low speed jet in the carb is probably clogged. Your local lawn mower shop should be able to fix for much less than the motorcycle shop.
Ares 110cc four wheeler won't start gas not getting to carb
chk your tank and lines for trash blockage, when you get fuel to the carb go from there, the overflowing is caused by the needle valve in the carb sticking open, usually caused by trash in the fuel, make sure you are getting fire to the plug as well, I know for a fact the wiring systems on these things are not quality systems.
