20 Most Recent
Weslo Cadence CT 4.8 Treadmill Questions & Answers
I can't find the safety key for my Weslo Cadence
You will have to purchase a new key unfortunately. First, go to
www.iconservice.com in the replacement parts link. There you can type your model number/model name found on your machine usually on the bottom of bikes and ellipticals, and underneath the belt when the machine is in spacesaver position on treadmills. It will give you a PDF version that you can download for free. You can also call for a hardcopy but it will cost around $20 with tax and shipping. The number is 1-800-999-3756.
When I put the key
hi,
You have to check the Driver circuit board for the motor. There is motor control IGBT Insulated Gate Bipolar Transistor) in this board .If the IGBT is short then the treadmill will try to run at high speed without setting any value or witout pressing the start button. You have to check the OHMS between the seocnd and third of lead of the IGBT. If it shows less than 100 Ohms then the IGBT is short and you have to replace the same. Also you have to check the connection to the control pannel. Is there is any loose conatct. Remove the connection in the motor control board which go to the control pannel and reconnect it. Also check the speed sensor. In most of the treadmill you can find the speed sensor near the motor pully. Remove the speed sensor and clean it and the refix it. Remember one thing remove the power of the treadmill and leave it for 30 minutes then only oppen the treadmill. Because there is high voltage storage capacitors in the motor control board which will hold charge for some time even after the power is disconnected. i ahve added the picture of IGBT for your refference
ok
My weslo cadence 845
There are Allen bolts on the bottom front of the treadmill as you face to console before getting on. Turning one one way and the other the other way will center the belt
I have a Weslo cadence 860 treadmill and have lost
We used a paint stick instead of the key - it fits quite nicely - didn't even have to modify the paint stick except cutting it down so it was shorter and my hubby shaved a bit off the side. We do remove it after the work-out however!
