I am afraid, this seems to be an issue with Control Board. This is one of the main problems with Front Load Washers.
Check :-
No power
Check
to see whether power is getting to the washing machine. Is it plugged
in? Has a fuse blown or is a circuit breaker tripped?
Lid switch
If
the lid switch is defective, your washer can't spin and may not
function at all. The switch is inside the washing machine main housing
near the door frame. Often you have to raise or open the top or front
of the washer to get to the switch. If it's defective, you need to
replace it.
Some machines have a special lid-switch fuse near
the lid switch, inside the control panel. If this fuse blows, the unit
won't fill with water until you replace the fuse.
Unless, pull out the Control Panel. Check if there is any burned resistor. and let me know.
Unless replace the Control Board.
Note - Before ordering any part, make sure that you have checked the fault with that part. Here, we can only make intelligent guess what might be the fault but you need to investigate from your end!!
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Do accept the solution, if 100% satisfied from my service!!
