20 Most Recent Thule 686 Atlantis 1600 Cartop Carriers Questions & Answers
2answers
I have a Thule Adventurer
Thule customer service is excellent and they will be happy to give you the exact answer you are looking for.
www.thule.com
4/15/2019 3:44:12 PM • Thule 686... • Answered on Apr 15, 2019
2answers
Strut on Thule Atlantis 1600XT popped off. How do I re-attach it?
Put your carrier on a pair of saw horses and clamp down firmly then open the lid as it now stable and clamp your strut with a wide jaw wood clamp. Apply just enough pressut to start the ball into the socket and finish with your hands. Steve Parks
2/6/2015 4:54:12 AM • Thule 686... • Answered on Feb 06, 2015
How do you take the
With the box open, loosen and remove the screws at the mounting points. There should be at least 4 mounting points, each has 2 screws I believe. You may want to have an extra person to help lift the box off your vehicle without accidentally scratching your vehicle.
7/10/2014 4:24:16 PM • Thule 686... • Answered on Jul 10, 2014
Lock is jammed
Spray some WD-40 into the keyhole in the lock and wait a few minutes for that to set in. Then try to turn it again. If that doesn't work, the lock cylinder may not be inserted completely. Use the removal specific "key" that comes with Thule locks to pull the lock cylinder out, then reinsert the cylinder completely before removing the removal "key".
7/10/2014 4:21:42 PM • Thule 686... • Answered on Jul 10, 2014
2answers
The catch/lock on the thule roof box broke - need
Any Thule dealer should be able to sort this one out for you.
Have a look through Thule's website to find the model and possibly you could get it online if it's sold as a user changeable accessory..
http://www.thule.com/Thule
4/16/2013 7:33:08 PM • Thule 686... • Answered on Apr 16, 2013
Key broken in box how do i remove locking device
same here ... bought new lock/key from Thule but no way to get old lock out
12/18/2010 1:58:25 AM • Thule 686... • Answered on Dec 18, 2010
Fxing cracked carriers
As you know when a solid piece of material is damages, the structural integrity of the item is damaged, and it doesn't help that ABS is a very unfogiving material. I see Cartop Carriers all over my city with scuffs on them because the things are simply easy to forget that they are even up there!
In my research on your issue I found a material that should fix your cracked carrier and ensure that you will have many more years of enjoyment with it.
To answer your question, Fiberglass is not the proper material to use on ABS. Fiberglass is essentially a "Band-Aid" on ABS because the bond will only last a couple of years.
For this job you will need to use a compound called "Re-Plast" manufactured by the automotive parts company Wurth.
The benefit of Re-Plast is that it hardens into a plastic that bonds well with ABS, and it bonds FAST! So work quickly.
The Re-Plast will give your carrier a "scar" but should patch up your crack and increase your structural integrity. The good thing about Re=-Plast is that if you want to, you can paint over it to match your carrier's coat, to conceal the "scar" even better!
You can order Re-Plast directly from Wurth on their website link that is found below.
https://shoponline.wurthusa.com/wurthusa/servlet/CyberVendor/category/G4240843/catalog/group.jsp/
If this does not solve your issue, or if you have any more questions, please leave a comment on this thread and I will be more than happy to assist you further!
Happy New Year!
Feedback is appreciated!
1/1/2010 8:52:33 PM • Thule 686... • Answered on Jan 01, 2010
4answers
Cracked thule box
www.recrepair.com is what Thule recommends you use to seal your crack :) -- it is an ABS patch kit and is waterproof as it is used for permanent canoe and kayak repairs. it is NASA designed.
I am using it on my Atlantis 1800.
12/31/2016 1:42:14 AM • Thule Winter... • Answered on Dec 31, 2016
Lid of my 2010 Thule Atlantis 2100 (silver) cargo
Hi there, I believe the silver is paint over black ABS; if so, my repair may help you. A large (8 metre) branch fell on my Thule box splitting the upper carcass in many directions (both seams and field areas), in addition to the complete break of a front lower segment. I decided to try and fix it despite finding a replacement. Well I have to say, it worked out great, and it did not involve expensive epoxy, adhesives, hot air welders, or any of the methods most commonly referred to. Thule's cargo boxes are made from ABS plastic. The same black plastic material used for your household domestic waste plumbing systems. Rather than use foreign (non-ABS) material as your binding agent, simply use ABS. By keeping the joint material native, you are essentially re-establishing the continuity of the original material. Take a small piece of ABS pipe (any scrap will do, just ensure it's ABS -- will say on the side) and grind it down in shavings. I used a rotary cutting tool with a bit that looks like a common router bit for rabbit joinery. This resulted in very small shavings. Accumulate enough shavings and place in a small glass jam jar with a lid. I had to cover roughly 1.5 metres in crack length and found ABS shaving volume equal to a couple marsh mellows to be plenty. Here's the magic.... pour a small amount of Acetone into the jar and stir the contents (do it outside as it fumes) -- add more as needed just to get it to the consistency of carpenter's glue. After you have bound the cracked segments of your Thule from the outside (I used rubberized packing tape as it has great horizontal field strength but can be removed easily). The tape up job doesn't have to be pretty, just ensure the edges are tight together and the tape is firmly holding it tight. On the inside, use a rotary cutting tool and any cutting bit to grind a trough directly where the cracks are. I went down approximately 3 millimetres and across approximately 8 mills. I left it rough to the touch. Clean the trough with Isopropyl alcohol; let dry. Using a small paint brush (ones you find in elementary school water colour paint kits are fine) "paint" the trough with the dissolved ABS from your jar. The advantage here is the Acetone in the mixture dissolves the edge of your trough so both the slurry (your mixture) and the hard carcass body are naturally bonding. As you might imagine, the Acetone will evaporate leaving nothing behind but ABS -- as hard as the original, fully bonded to the original material. Once dried, apply additional coats to build up the trough to your preferred profile. Remove the tape on the outside and you're set. You could apply some sealant to the outer surface of the cracked area, but I did not as keeping it clean to look at on the outside is difficult when adding to the perfectly smooth outer surface.Good luck. lid-2010-thule-atlantis-2100-silver-uj5yyv2q0ahr5z2plldwesul-1-0.jpg
2/6/2015 6:20:41 AM • Thule Winter... • Answered on Feb 06, 2015
How do mount thule 515-0109 bike rack on suburban
It attaches to the factory roof rails if you have them. If your vehicle doesn't have those, then you need the gutter mount feet for your Thule rack.
7/10/2014 4:19:07 PM • Thule Winter... • Answered on Jul 10, 2014
I need mounting instructions for Thule 598
Here is the only manual that thule has.
http://www.thuleracks.com/manuals/598_.pdf
You might want to contact them here on link below.
http://www.thule.com/en/US/Support/Customer%20Service.aspx
1/27/2010 5:33:00 AM • Thule Winter... • Answered on Jan 27, 2010
I have a 2006 Polaris 900rmk snowmobile it keeps overfueling at idle I believe it is one of the injectors on pto side not sure which one of the 2 affects your idle any ideas?
they both can repair manual show how to trouble shoot --------https://snowparts.ru/manuals/Polaris%20Trail%20600-900%20RMK%20Switchback%20Service_Manual_2005.pdf
1/10/2023 1:06:51 PM • Winter Sports • Answered on Jan 10, 2023
No spark on 02 ski doo legend
You have a bad coil or wire.
1/3/2023 2:25:15 AM • Winter Sports • Answered on Jan 03, 2023
2answers
Spark plug gap on a 2006 Polaris 700 Classic
It depends on the brand of spark plug you are using. https://www.google.com/search?q=2006+Polaris+700+Classic+spark+plug+gap ..
12/18/2022 3:53:35 PM • Winter Sports • Answered on Dec 18, 2022
2answers
Wearfit 2.0. Why can't I bind to my iPhone?
Discord users facing issues like How To Fix Discord Not Opening so just make a call on Discord Customer Support 1-802-618-6092 anytime and experts are there on Discord Live Chat to help you 24*7 . Need any kind of guidance to fix the Discord issue so just make a call on Discord customer Service 1-802-618-6092 anytime and fix issues, a helpdesk is there to help you 24*7
2/24/2022 9:59:23 AM • Winter Sports • Answered on Feb 24, 2022
2003 Ski-Doo Grand Touring 550 Fan. All of a sudden I have no spark! What could be the problem?
kill switch --ign switch--cdi--magneto--broken wire --etc https://ski-doo-snowmobile.brssm.com/ https://www.snowmobilerepairmanual.com/ski-doo-repair-manual/
1/16/2022 5:08:05 PM • Winter Sports • Answered on Jan 16, 2022
Skandic Skidoo. How do I take out a battery that is located underneath the seat of a Skandic Skidoo
Question edited for clarity. Question moved from Seat Cars (Spanish car maker and pronounced See-at) to Snowmobiles Category. The are videos and text based articles. The best bet is to fit pigtails to the battery and had a plug for a battery maintainer. You never have to remove the battery, and you never have to worry about it it not being charged. https://www.google.com/search?q=skandic+skidoo+remove+battery ..
1/15/2022 10:33:14 PM • Winter Sports • Answered on Jan 15, 2022
2012 Switchback adventure 600
MAYBE IT NEEDS SOME OIL ADDED
1/4/2022 7:51:27 PM • Winter Sports • Answered on Jan 04, 2022
3answers
What types of waxes are used in cross-country skiing?
There are four different types of waxes that are used: waxtapes, glide waxes, klisters, and kick waxes.
6/25/2021 3:58:02 PM • Winter Sports • Answered on Jun 25, 2021
Thule 686 Atlantis 1600 Cartop Carriers Logo
18 questions posted
Top Thule Winter Sports Experts
Arnie Burke
Arnie Burke
john h
ADMIN Andrew
ADMIN Andrew
Are you a Thule Winter Sport Expert? Answer questions, earn points and help others
View Most Popular
Thule Winter Sports
  • Thule Winter Sports
Most Popular Question
key broken in box remove locking device
  • Winter Sports
