20 Most Recent Electrolux EOD5330 Ultrafan Electric Double Oven Questions & Answers
Hi, Just had a new
Best get in touch with the company you got it from. Do not play with it as it should be covered under the warranty. i say electrolux should see it.
9/17/2017 12:26:40 AM • Electrolux... • Answered on Sep 17, 2017
0answers
Queries
You could use a dishwasher if you remove the glass panels. I would be leery of breaking the glass panels. They are not cheap, be careful.
3/29/2014 6:13:35 AM • Electrolux... • Answered on Mar 29, 2014
Element
Depends on where you are located. Are you in the U.S. or no?
12/28/2012 7:46:51 PM • Electrolux... • Answered on Dec 28, 2012
2answers
Replaced fan oven element but now now fan and no
remember to set the time of day on the clock it wont work until you do.if you have done that then it could be clock relay contacts that are faulty.
8/8/2011 4:28:55 PM • Electrolux... • Answered on Aug 08, 2011
My electrolux EOD5330 fan oven tripped a fuse. ow
Most likely problem is the the oven element short circuited which caused the fuse to blow. When power is restored everything generally works except for the element. If you check the element you may find a blow hole in it.
2/12/2011 9:57:42 AM • Electrolux... • Answered on Feb 12, 2011
0answers
Heated oven to 200 and on putting food in the oven
that was your element burning out. you can change it from inside the oven but be carefull not to lose the wires. if you do you have to take the oven out to reconnect them
8/6/2010 7:51:08 PM • Electrolux... • Answered on Aug 06, 2010
Electrolux eou43002x
probably element failure. located round the fan at the back.
7/16/2010 9:19:41 PM • Electrolux... • Answered on Jul 16, 2010
Heard a pop/bang and now no heat
It would seem that the ring element surrounding the oven fan has burnt out and will need replacing.If you are good at D.I.Y Then you would be able to replace yourself as long as the power is off.The part no. for new element is 3117704001 and costs € 26 Euros in Ireland.
Hope I helped.
5/12/2010 7:18:52 PM • Electrolux... • Answered on May 12, 2010
The oven light is on, the fan is spinning but no
could be the element, or the thermostat
4/7/2010 4:08:35 PM • Electrolux... • Answered on Apr 07, 2010
2answers
Sounds like the oven element has blown.
To fit a new one, remove cover at rear of inner oven compartment, there you will see the round fan element.
4/7/2010 4:07:43 PM • Electrolux... • Answered on Apr 07, 2010
Main oven doesnt heat up. But temp light is on.
replace heating element
6/22/2009 5:04:15 PM • Electrolux... • Answered on Jun 22, 2009
Electrolux EOD5330 Ultrafan Electric Double Oven Logo
28 questions posted
Top Electrolux Ovens Experts
john h
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
View Most Popular
Electrolux Ovens
  • Electrolux Ovens
Most Popular Question
queries
  • Ovens
