20 Most Recent
Electrolux EOB5610 Ultrafan Electric Single Oven Questions & Answers
My electrolux EOB5610 wont heat
Thanks for choosing FixYa and welcome. you have a electric oven or a gas oven that won't heat or doesn't heat properly, here are some things you will need to check. The most likely cause of a oven not heating correctly is a defective heating element. You have two types of heating elements in your oven. The bottom element(s) are the baking elements. The element(s) on the top are the broil elements. If you don't see the bright red glow from the element, chances are they are not working or not working correctly. If a heating element is bad, you need to replace the entire element. If your oven is warm and not correctly hot, one of the elements may be bad. In most ovens, when you preheat, both elements are used. This would make the oven to appear like it is working correctly but it is not. If the elements are not working, they might not be getting power. Test the wires to the elements with a voltage meter to make sure they are getting power before you decide to change them out. Many electrical ovens have a sensor that monitors the oven temperture. Ovens that have this sensor usually contain a digital display on the oven. The sensor could be defective. Those without the sensor use the basic mechanical system to control the oven temperature. You also want to check the thermostat sensing bulb. Make sure the bulb is good and has not come loose. Now, if you have a gas range oven that doesn't heat properly, first, you want to check your bake igniter. It may have burned out or it could be not working properly. It will be located near your burner. It is also possible that you are not getting gas to the burner. If so, it may be the gas safety valve or the igniter. You need to check your selector switch and thermostat as well. They may be defective. Always make sure you test the parts for power with a voltage meter of some type before you decide to change the part. If you have a part that appears to not be working, it may not be getting power because of a bad wire or broken connection.
My Electrolux EOB5610 fan oven will not heat up.
Only two possible causes. The oven element is faulty or the oven thermostat controller is faulty. Probably the first thing to do is test the oven element and check the resistance. If the element is okay then the oven thermostat will need replacing.
Sounds like you element is faulty. You can check it by removing the panel in front of the element which is held on by 4 screws then you can visually check it to see if it has blown. If it looks ok then unscrew the element and carefully pull it towards you a couple of inches, this will allow you to pull the 2 wires off, make sure the wires dont fall back inside the machine or you will need to remove the back panel. The use a multimeter on the buzzer or sounder setting and place a probe on each of the pins on the element and if it doesn't buzz or sound then the element is faulty. Make sure you have the electric switched off at all times. Hope this helps
Hi
The fan is this oven
You need to change the fan motor. These motors are not very powerful and wear in the bearing can cause this effect. oiling the bearings is only a tempory fix and you will eventually end up changing the motor.
Fanforce oven
usually you have a bake and a convection button if you only one button for baking you may not be able to use bake with out the fan good luck
Electrolux Oven 5d or Sd error code/demo mode
- Turn off the oven.
- Press and hold the "Bake" and "Broil" buttons.
- Turn the oven on by pressing the "On/Off" button.
- Continue holding the "Bake" and "Broil" buttons until the display shows "PF" or "8.88."
- Release both buttons.
If these steps don't work, refer to the user manual or contact Electrolux customer support for further assistance.
