20 Most Recent Canon i-SENSYS FAX-L150 Laser Multifunction Printer - Monochrome - Pla Questions & Answers
Code
E225-0001
Description
Light intensity of a lamp is less or equal to the criteria
Remedy
When the same error repeatedly occurs after several times of turning the power OFF/ON, execute the following remedies.
(1) Check the connection of Flat Cable between Main Controller Board (J5) and Contact Sensor.
(2) Replace the Flat Cable between Main Controller Board (J5) and Contact Sensor.
(3) Replace the Contact Sensor. (4) Replace the Main Controller Board.
Canon i-SENSYS... | Answered on Jan 20, 2019
Try unplugging it for a few moments they plugging it back in.
Canon i-SENSYS... | Answered on Jul 21, 2017
hi
I need to CODE reset factory default printer
model : CANON L150
Canon i-SENSYS... | Answered on Feb 08, 2017
How to resolve the code 225 in Canon Fax 150?
Canon i-SENSYS... | Answered on Nov 08, 2016
First things first. Try and print report from the fax. Any kind of report. If it is printing OK, then the next step is to check if:
Your clients receive your faxes OK? If they are dark as well, then your scanner head is at fault.
When you make Copy on your fax and it prints dark it could be simply set with dark settings _or_because of the white calibration strip or roller being soiled or dirty, which acts as the ultimate white reference point for scanner _or_ the Scanner CCD sensor is in paper jam release position (too far away from reading the originals) just pull it back to normal feed position.
Or simply faulty scanner.
Canon i-SENSYS... | Answered on Sep 30, 2016
Go into the menu. In the FAX Settings the RX Mode Settings section and turn on the FAX ONLY setting.
If all is well then it will receive. If it does not then check that you are using the genuine Line lead that can with the machine.
Canon i-SENSYS... | Answered on Feb 28, 2016
Canon i-SENSYS FAX-L150 Laser Multifunction Printer - Monochrome - Pla Logo
26 questions posted
old marine
old marine
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
View Most Popular
FAX Canon
  • FAX Canon
Most Popular Question
will reason canon sensys fax l 150
  • Office Equipment & Supplies
