20 Most Recent
Epson WorkForce WF-2540 All-in-One Inkjet Printer Questions & Answers
My Epson printer prints & copies black sheets but will scan and print ~ installed new drivers & new ink - Help
I think you meant that its print and copy function is generating only blank sheets and that you have installed new drivers and new ink. You do not mention whether you tested the printer before making these changes. There are several possiblities such as clogged nozzels, incorrect paper size, or the cartidges not being locked into place. Have you tried activating the printer's cleaning cycle which might unclog nozzels?
The most immediate fix would be to turn it off via the power button, disconnect all cable including unplugging it was the power outlet, wait three minutes, reconnect the cabling and connection to the outlet. Fire it up and try printing a test page.
Epson has a Troubleshooting page where it requests the model number in order to make targeted suggestions.
https://epson.com/support/wa00903a
My pinter is off line
Epson Printer Offline Windows 10 normally relates to a printhead incident, and the displayed error information will flash on the computer. The lights will begin to blink as a symbol of this Offline 10 window. Caused by any international garbage inside a printer roller or due to a paper jam in a printer and many other PC reasons. If the issue persists, check this blog or call Epson Printer Repair Services or Printer Support to avoid further printer damage.
Epson printers are cost-effective printers that give up writing. In addition to copying, a user can copy and search from a printer to a USB link as well as a wireless link. In Epson printers, an offline malfunction occurs once in a while. This write-up teaches you about the causes of this mistake and its remedies. We've read 'How to Address Why Epson Print Outline Problem' for both Windows and Mac operating systems.
Reasons that Cause Printer Offline Windows 10:-
1. Paper jam fault.
2. Paint toner blockage.
3. Fault in the network attachment between your Pc and printer.
4. Corrupted or old printer drivers.
Our Service: We give online help for Any problem with printers our Call us on TOLL-FREE NUMBER in our BLOG.
Blog:
Epson printer offline windows 10 <--Check here.
It has a message saying printer error.turn power off and then on again.
It sounds like the printer failed to update the firmware properly. Click on this link and click on the Firmware tab. You should see firmware recovery. Download it and follow the instructions. The Epson must be connected to the computer via USB cable for this to work.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?infoType=Downloads&oid=209708&platform=OSF_W_7-32&detected=yes
Waiting for printer to become available error
Is this the error message you are getting? If so, it looks like that there is a long queue waiting to be printed and there is some error. So you have to check the printing queue and delete all and it should show '0' waiting at the printing queue.
I need to pull an 11" x 48" sheet through my printer
The widest paper to fit through is 8.5 inches. You can print up to 44" in length though.. from a Google search:
Automatic Document Feeder: 30 sheets. Paper Sizes: 3.5" x 5", 4" x 6", 5" x 7", 8" x 10", 8.5" x 11", 8.5" x 14", A4, B5, A5, A6, half letter, executive, user definable (3.5" - 44" in length) Maximum Paper Size: 8.5" x 44" Borderless Sizes: Photo: 4" x 6", 5" x 7", 8" x 10", 8.5" x 11", A4, 16:9 wide.
