20 Most Recent
Lexmark CS510de color laser printer Questions & Answers
Lexmark manuals
40X5168 is for the pick tyres
40X7628 is for paper pick motor drive assembly with motors.
Maintenance kit in display
some models if you hold down the enter or mode button for seven seconds should clear also should be in manual or check with who carries that model
Why does the data light blink then paper jam light goes on even with no paper in it
Most likely when you removed the paper jam a small piece of paper got jammed under one of the sensors. This is a very common problem. It is also possible depending on the model that you have dislodged one of the flags that activates sensors for paper travel. Check the back of the printer in the fuser area as these are the most commonly damaged sensors.
