20 Most Recent
Columbia All Sport watch Questions & Answers
I have a columbia watch
mcdevito75 here, Basically there are 3 ways to remove the watch back, If there are 4 screws holding the back onto the caseing you"ll need jewelers screwdrivers to reove the screws and cover, if there are square holes going around the edge of the back cover you"ll need a special tool called a case back remover tool available on ebay to un-screw the back cover, or the cover simply prys off. Look for a tiny tab on the back cover you may need a magnifier glass available at most Dollar stores or there may be a **** between the back cover and case of the watch to pry off the back cover, use a sharp knife and carefully twist the knife oncwe you find this tab or ****.
I don't know how to set the time on it
Use this link and browse through my TIPS AND TRICKS: http://www.fixya.com/MyProfile/tips.aspx?usrid=1700524.
You will find manual for your watch there.
HOW TO SET TIME ON COLUMBIA WATCH CL5068
Go to
"www.columbia.com/Equipment-+-Accessories/Licensee_Landing,default,pg.html"
Under
"Timing" you will see a link "PDF.............", click on this
and a
list of diagrams will appear. Choose the one that looks like yours
and
follow the adjacent instructions.
How to set a columbia water resistant watch
To get a set of instructions, go to their web site (/www.columbia.com).
In the search box at the top right of the page insert "watches" and you will see in the center a picture of a watch, select "PDF......." and the watch manual will appear, choose the one that similar to yours.
Nedd help setting time on columbia watch
Ple disregard all prior instructions. They are either wrong or a step was forgotten. Press "set" for 5 seconds. Then "mode" until you see 12-Hr flashing in the window, then press "ST/SP" until you see 12-Hr flashing, then press "mode" again until you see the word "hour", and the actual hour is flashing. At this point, you may increase time by pressing the ST/SP button or decrease by pressing the "Reset" button, then the "set" button. Enjoy!
SET THE TIME
: 1. With the time and date showing, press the top left button. 2.Press the right top button (this sets seconds) 3.Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm). 4.Press the bottom left button, minutes flash. Press the top right button until correct minutes. 5.Press the bottom left button, month flashes. Press the top right button til correct. 6. Press bottom left button, date flashes. Press the top right button til correct. 7. Press bottom left button, day flashes. Press right top button til correct. 8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished). To turn off the chime and alarm, press the top right button repeatedly until the CHIME or CH symbol is gone, then press the left top button. Repeat for alarm but watch for the bell icon or ALARM or ALM to disappear, then press the top left button.
