20 Most Recent
Vizio E320i-A0 32 Class LED Smart TV Questions & Answers
Vizio e320i-a0 that flicker constantly
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
How to access the usb input from the tv screen?
- To play USB media, you must first save your music or images onto a USB thumb drive.
- Remember: The USB thumb drive must be formatted as FAT32.
- Files on the USB thumb drive must end in a supported le extension (.mp3, .jpg, etc).
- The player is not designed to play media from external hard drives or mp3 players.
To play your USB media:
- Connect your USB thumb drive to the USB port on the side of theTV.
- Highlight the Media app and press OK.The Media App launches.
- Highlight your USB device in the list and press OK.
- Highlight the type of media you wish to display: Music, Video or Photo. This info can be found in the manual here: http://cdn.vizio.com/documents/downloads/hdtv/E320iA0/UM_E320iA0.pdf
