Hello, to restart your HP Assistant you must first sure that you have install it in your system then go to control panel then open HP Wireless Assistant then check the properties then modify it. Then press the button with an antenna with a wave at the top to enable your wireless connection. Make sure that you enable your wireless connection for you to have HP Wireless Assistant.
These are the reasons why your pc wont switch on
1. Defective power adapter
2. Defective Processor
3. Defective Motherboard
Note: If you replaced your motherboard check the specs on the previous motherboard it should be the same part number or a replacement part number.
You can purchase your motherboard to HP System Board HP Motherboard
Here's a sample video
Try using a known-good (for instance, a movie you just watched on your TV). If it doesn't read that disc, make certain you have seated the disk in the drive properly (Laptop drives have a *CLICK!* when you have seated the disc properly). If that doesn't work- if the laptop is in warranty, get it fixed. If not, use an external drive to fulfill your media needs I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
First of all where is this laptop used? On a hard surface or on your lap? I would invest in a notebook cooler you can get a decent one for about 20-30$. Secondly you may want to get some computer air and blow it into the vents on the laptop. Your last option would be to take it apart and clean out any dust thoroughly although this option is difficult and should only be done by a computer tech. thank you, Lee
Hello, If it a hard shutdown that you experienced, then, i should beleive that it is from the board. what i mean is that you have to change the processor of your laptop, then it will come back alive. But if it does not come back, you should know that the board has to be changed enterly.
usually hp computer have a really bad disipation design, i would thing it,s indeed the video chip, allthough you can conect a regulat screen in the back of it & if it woks fine then it might be something else.. but i bet is a video chip problem, do a reflow on it or have some one do e reflow on it or a reballing work on the video chip, or it might be cheaper to get en other system board off ebay
use any win-based live cd [or transfer drive to desktop pc as secondary]
to download newer drivers and override broken ones
linux live cd may not work as may not read drivers correctly
Probably have a bad mouse button on your palmrest. Try using an external mouse... does it right-click? If it works fine then you have a bad mouse button and will probably need a new palmrest to fix it.
If it still fails to right click with another mouse, then it is just a software setting in your PC, check your settings in control panel in the mouse options.
no pc told, Pavilion means zerothat name is is used on desktops and laptops for agesthe HP has diagnostics so run those. HP.com tells how.not told desktop or laptops. just 1 word."Screen"first Pavilion was 1995
learn to google mate.
this is no secret,gee millions sold.
A6Y530A
the partsurfer shows true model, and fails
this is the only post here ever asking for reverse code lookups
on models fake, and is not easy in vast cases
I guess you have no such PC, (look like)
so why ask this>? what prompted this quest>? not told
why not ask seller for photos of it if this is a pre sales question , is it>?
google and bing and HP all show that model # is BOGUS
so go back to your sell and ask the we can not guess PCs ever.
HP product ID# is best on the service tag for SURE.
where did you see this number, not told.
or that number is some 20+ year old COMPAQ PC ,lost in the sands of time, and no google hits.
you posted to HP forum, (not real) Hp.com is real
what does not working mean (KBD) dead, or 1 key bad or row. what?
symptoms matter most, for sure in a LAPTOP IS IT
the word Pavilion is on laptops and desktop, dig?
G mean zero , the service tag does not just say "G" sorry.
easy peasy lemon squeezy
HP.com
complex URL no?
go there
tell them your model # or better the service tag code ! .
then magically HP puts you on YOUR service support page
and all manuals and all driver before your eyes. amazing no?
NO told at all
or of a laptop or desktop or what./?
you posted ANON so I can't just read other posts by you to learn what PC this is , no I can not.
there are over 100 PC called G series, and vast years.
some PCs by them G1 to 7 are generations, like
HP Pavilion g6-1029tx Notebook.
if you can find the service tag the product ID # is what matters most
this code includes (real model, version , options and country sold)
see this, older PCs by them had this.
see that , all matters but do not post SN/ or service codes in public.
mine: procuct code (nnnnnnABA#)
https://www.pcdied.com/TAG-jive/tag-elite8540w.JPG
I will guess it is 17" laptop, here is the mess just that 1 sized
once you see this you know that G series means not MUCH>
https://search.brave.com/images?q=hp+G+series++pavilion++17%22+G&source=web
old PCs do that, for many reasons. but no PC told at all just HP.
40 years of PCs ,10000 + models nobody can guess ever.
but I do have the answer, in pure generic form.
did you buy the PC like that used and bad Wifi. ?
the wifi card is missing, as was super common 10+ years ago.
someone put in the wrong card, not from HP list
HP blacklists (bios blocks) none HP cards (wifi)
the card needs a driver to work if not it is dead or 1/2 dead.
the PC needs 1 more driver to make the wifi buttons all work , all buttons related, if not they are dead or act odd.
The OS is infected, no OS told at all, not one clue nor if upgraded the OS, and not vast drivers are wrong or missing, (classic)
Im sure this this is not the free w10 upgrade, if it was that too kills drivers dead, for sure HP told you this unstated PC will not run W10 and has zero support from HP, on w10 AS YOUR SUPPORT PAGE WILL DISCLOSE TO YOU AT HP.COM
